    Jul 2002
    NorthEast
    1) When I upload the N30
    I receive Connection in Progress please wait
    This repeats for about 40 minutes
    Nothing happens
    In Project Builder / Edit Site
    does the Site Manager Device and Copy Holder Device
    have to use the exact name as the N 30 that I
    am trying to Direct connect to.
    The N30 in my database matches the name of the N30
    How long can it take to upload an N 30 via a null modem cable.
    Thank You
    San Francisco Bay Area
    I've seen an N30 take over an hour to load via a serial cable. That's why I use a serial connection as little as possible - long enough to determine the N30's name, and perhaps its IP address, then it's a crossover cable and Ethernet connection all the way. N30 loads then take less than 5 minutes.
    Jul 2002
    NorthEast
    If I wish to use a crossover cable
    Then I have to establish it as an Ethernet connection type in Site Book?
    Thank You
    Yep, that's absolutely right. You'll enjoy the huge speed advantage by ditching the serial connection for an Ethernet connection. I couldn't imagine how long it would take to browse a device in the Sitebook with a serial connection - with an Ethernet connection, a fully loaded N30 is usually browsed in about 30 seconds.
    serial connection
    If you are waiting 40 minutes and see the same word, then you have a problem.
    You should do a test by connecting to the N30 using the direct connection you made. This will ask you for a password, enter it and see if you can get in. When you are in, check the speed you are at. Using Project builder should not take this long.
    And I agree with davem that the ethernet is the way to go.
    good luck
