Results 1 to 8 of 8
Thread: network 8000
    Hmm
    I have an network 8000 that does not have a key pad. How can I get into it to see setpoints and things
    Jul 2001
    Canada
    Will require either PSI software for terminal mode or the graphics package SIGNAL
    Apr 2003
    South Carolina
    rs232 cable and hyper terminal and the proper login
    Jun 2006
    Is there a GCM? If there is yellowfrog76 is right on the money.
    Jul 2001
    Canada
    As well as a GCM it can be a MZII , LCM without keypad or even an old GCS but that would need a GCM
    Connecting to a MZII is different than the other NETWORK 8000 devices and requires rs232 / 485 convertor
    this network 8000 has the enter , esc, > < and up and down thas all
    Jul 2001
    Canada
    You can do quite a bit with that keypad , but you really need the manual, usually the LCM has the small pad , GCM has the larger pad with full alphabet and #s.
    Jul 2002
    Have you tried your local rep? I'm sure they would be glad to help.
