Results 1 to 6 of 6
    Jun 2009
    Alberta, Canada
    keeps going and going and going
    http://s42.photobucket.com/albums/e3...-12-44_630.mp4
    I said it's a lennox. but actually its' ICG. the pee rot has gotten larger by the time I finished the call. it's a rental unit. and the owner was wondering why she kept spending money on it. I've told her to replace it before, but I guess my coworker put a rescue motor in. in the process might bent the blades, although the blade looks ok. could be the rescue motor it self.
    Have tools and gauges, will travel.
    RIDGID|YELLOW JACKET|UEI|TESTO|STANLEY|CPS|VETO| KLEIN|MILWAUKEE|MASTERCRAFT|
    Tallahassee, FL
    I do not know what to say. Good luck to you my friend. Canada will be cold soon.
    Like the sig.
    Dec 2010
    Woodbridge Twp, NJ
    Yeah I bet that won't develop a leak. I've seen 30 hp compressors that don't make that much noise.
    Every customer you take for granted today will be someone else's tomorrow.
    Oct 2011
    Chicagoland Area
    Canada? The accent sounds like Minnysota
    Jun 2009
    Alberta, Canada
    marshall erickson doesn't sound like that... hahaha (HIMYM) never heard minnysotan speak.
    all the owner want is that time bomb to surviive til sept 5 when the house close and she doesn't have to deal with it ever again. I found it hard to believe that my co worker said he didn't test fire the unit after he installed the rescue motor. its possible that no one there, but if no one there I wouldn't do it. it has no disconnect box, so you have to go inside to shut the breakers. if the breakers off the tenant would've call us again to flip the breaker, since all they know that the AC is not working. that unit has tripped the breakers couple of times. max fuse is 30 amp and total load was only 12 A at the most. compressor LRA is 68 A tho... new FPE panel box, at least within the last two years.
    Jun 2012
    San Francisco Bay Area
    Put that thing out of its misery already haha
