Page 3 of 3 FirstFirst 123
Results 27 to 35 of 35
  1. #27
    Aug 2012
    west burbs,il
    You do need to post more info. Did you replace filter drier or cut it out all together. If did remove filter completely did you vacuum system completely, you probably have a ton of air in the system. I know your pressures were fluctuating but what were the approximate pressures before repair? Does it have same problems after fixing issue?
  2. #28
    Nov 2007
    Mississippi
    Gonzo, did you fix it?
  3. #29
    Sep 2012
    what is the flow rate, supply & return temperature?
  4. #30
    Jul 2009
    Columbia, MD
    what does IIRC stand for?
  5. #31
    Mar 2011
    Long Beach, CA
    Quote Originally Posted by gravity View Post
    IIRC?
    Whats this? Do I have to learn the meaning of a new acronym ? Just when I thought I knew it all.
    I will wait for the reply so I can jot it down right away.
    Trouble shooting is not part of the repair..........understand the symptoms and you will find a solution.
  6. #32
    Nov 2007
    Mississippi
    x2
  7. #33
    Jul 2009
    Columbia, MD
    ive seen it before. it even saids it in a lennox air handler book. something about an IIRC piston or txv...blah blah blah
  8. #34
    Jul 2009
    Columbia, MD
    funny...
    IIRC = if i remember correctly?
    i have also seen IIRC in a lennox manual though. i don't think Lennox meant it as the same
  9. #35
    Nov 2007
    Mississippi
    Ha. I can buy that.
