Results 14 to 26 of 35
    Oct 2008
    Massachusetts
    Clear your head get yourself well positioned and think it through writing down all the data you grab and see what jumps off the page. Obviously head pressure is low and suction is high. Bad valves? Why would amp draw be normal at that case? Is it also overcharged because someone added gas at some point to 'fix' the faulty valves?
    If you could valve off the high side I'd see if it could hold it's mud. That's a quick way to prove out the valves. Bad valves won't pump down especially if its over charged but this is an RTU right so no go on that.
    What's your delta across the coil?
    Shophound makes an excellent point in knowing whether your gauges are correct before you take all this for granted. I've spun my wheels on a few occasions only to later realize my test equipment (gauges) were giving me bad data.
    Jul 2012
    amps are 5.1 give or take a point ort two on other legs, in specs according to manufacture data plate.
    Jul 2012
    my Delta was 11f.
    Jul 2012
    Thanks, and nice bike in your picture
    Aug 2012
    5amps seems a little low for a 5ton system. Bad compressor with dirty condenser coil or non-condensables in the system.
    Aug 2011
    Chicago
    Discharge superheat higher than 50 deg might have broken ring or
    Cracked piston. If its a recip. Can you pump doen either wirh suction valve or liquid solenoid/valve? If it does not pull 15" you have issue in comp. Conpressors suck and blow the less they suck the less they blow
    Oct 2005
    Quote Originally Posted by socotech View Post
    Gonzo, if your evap was dirty you would have a low suction and low superheat.
    yup
    RTFM!!!
    Oct 2010
    Did you pull a proper vacuum when after installing drier, what caused the drier to stop up. If drier was stopped up if it has a screen anywhere in the system it is likely stopped up too.
    Lol
    I can just about guarantee that thinking is wrong.
    Jun 2012
    Quote Originally Posted by jtel View Post
    Discharge line temp could be used to check the compressor.
    High Side Sat temp should be +20 ambient (15-50 superheat on DL).
    Low temp IIRC no heat of compression.
    Jun 2012
    Quote Originally Posted by Gonzo2611 View Post
    my Delta was 11f.
    Just not pushing enough liquid to the metering device.
    Let us know how it goes, low split backwards high/low my moneys on the compressor.
    If it was a Heat Pump bad RV could produce the same numbers.
    Nov 2011
    GA
    And high TD, not 10*...... Superheat?subcool??? Anything relevant?
    Nov 2011
    GA
    Quote Originally Posted by LU91Tech View Post
    WhAT IS ThE (RLA)
    "Within specs" tells us nothing
