Results 1 to 13 of 19
    Aug 2012
    Is the activent really going to save me 30% $$$ per year on energy bills?
    http://www.theactivent.com/save.html
    The above product claims "up to" 30% energy savings per year. Their test data is based on ONE home. Does any professional have any real world experience with this product? Do you recommend it?
    My home has ONE big central air supply and one return, that cools the central great room very well, but the 3 peripheral bedrooms tend to be a little warmer. I probably need to undercut the doors to get some more cooling. My home has 10 vents. At fifty bucks a vent, it adds up. But theoretically I'd only need vents in the Great Room. Once that reaches say 75 degrees F, then the activents would close and then the peripheral rooms would be cooled more.
    Here's why I dont' believe the hype. My thermostat is in the Great Room. Right now it cuts OFF early because the Great room cools down quickly while other rooms remain warmer. If I install the activent, wouldn't it make the HVAC system run longer since the peripheral rooms would receive the balanced of the air, thus making it run a bit longer?
    Jun 2001
    Looks like a cheesy zoning attempt. The money is much better spent fixing the ductwork.
    Apr 2012
    winnipeg
    nope.....
    Oct 2010
    Quote Originally Posted by carmon View Post
    nope.....
    No
    From the sizes, and type of throw, of the ones for sale in their store, it looks like they are only for floor vents.
    SW FL
    I'd anticipate upto about 6% savings.
    Designer Dan
    SW FL
    Quote Originally Posted by newstudent View Post
    Activent
    only recommends 2 [ or 3 Max] for a residence with 10 vents.
    Given a 6'F differential temperature between bedrooms and living area, one might expect to improve it by 2, 3 or 4 degrees.
    Designer Dan
    I'd under cut the doors first.
    You would probably need some of those vents in the other rooms that cool ok now. Since the air that wouldn't be going to the great room anymore will come out the next easiest path, which may not be to those bedrooms.
    Massachusetts
    This is a product specifically designed and marketed to people who think there's a free lunch. For starters, a properly designed and installed system doesn't have the wide temperature variations this products needs to have any affect. Second to that issue is that the current system will perform based on the thermostat location and the resulting air delivered to each room during the heating or cooling cycle. When the room with the t-stat is satisfied, the system shuts down. As a final note, if you have cool rooms relative to other rooms in the house, this is an indication that insufficient Btu's are being introduced to those rooms during each heat cycle. So installing any device to ADD Btu's to the room will increase the fuel consumption/energy bill, not lower it. Thus, energy savings of any type would only be accomplished in rooms that are currently over heating. I will say that I've solved more than one problem using a similar method of a 'non-voting' zone damper installed in a single supply outlet and controlled by a t-stat that can ONLY stop the flow of air at set point but cannot bring on the equipment. In that respect, it does the job of improving comfort but I've never had anyone ever tell me they saved any money/energy with such a set up.
    Saint Joseph, MI
    I suppose thsi could help if you have massive imbalance issues and are overconditioning one part of the home to get the other to a comfortable temrpature. You nca also just balancea system with zone dampers.
    A properly size, installed, and balanced systme will have all room within 0.5F other than large swings in solar heat gain if there are a lot of south facing windows or a room with appliances or high occupancy (kitchen, dining room, family room)
    Aug 2012
    Is there a system out there that would close vents to large rooms at night like the living rooms and thus redirect heat/cool to bedrooms? I guess the trick is somehow having a second thermostat in the bedrooms, otherwise the bedrooms would get too hot.
    Fort Worth, TX
    It's a poor man's VAV!
    Your time is better spent evaluating the uncomfortable rooms to find out why they are not receiving or relieving enough air to keep the rooms comfortable.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Aug 2012
    OK I agree. Let's assume all rooms are fixed so they are always comfortable. Would having someone install some HVAC zone dampers in the living room ducts connected to a programmable timer so they close only at night time only help me save energy? I'd live to have the living room not heated/cooled from 10pm to 6am every night.
