Results 14 to 20 of 20
    Tallahassee, FL
    Yep you are right Vegas. I was mistaken
    Aug 2012
    west burbs,il
    Additional infractions may result in loss of posting privileges.
    Aug 2012
    west burbs,il
    Mar 2009
    Mount Holly, NC
    most 80% equipment use aluminized steel tubing, or pinch welded expanded plates for the heat exchanger, and it's bound to fail at some point.
    most 90% equipment uses extruded stainless tubing for both the primary and the secondary heat exchangers...
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    canusayinsanity
    Aug 2012
    We'll it looks like I'm down to the following on the furnace side:
    Amana AMH95 or AMVC95
    Trane XL95 or XV95
    Still not sold on aluminized steel though. Seems like stainless steel is the higher quality design. But they both have lifetime on the heat exchanger so perhaps it doesn't matter.
    Cincinnati, Oh
    Quote Originally Posted by dmileusnich View Post
    Trane XL95 or XV95
    Between the amana's, go with the AMVC95. It is a better furnace between the two.
    "Just get it done son."
    Dad adjusted
