Page 1 of 9 12345678 ... LastLast
Results 1 to 13 of 115
    Feb 2012
    Nebraska
    Digicool super sensor failure
    I got my AK900 about a month ago, and have been using the upgraded sensors. I love the way it has been working, but today my sensors have been acting up.
    The highside temp sensor is reading same as low side sensor.
    The stock red and blue sensors work, so I don't think there is a problem with the head unit. If I could get some insight of why this would occur, I might be able to locate the problem.
    I spent the extra Leg for these sensors, so I could avoid this issue. Gahhhhh
    In the work truck
    Did you make a phone call to digicool or did you come here first? Im sure they will have a solution that you will be happy with!
    Gotta have the right tool for the job!
    Where is all the stuff MADE IN THE USA?
    "Thats what we do Troy. Incredible, Invisible, Imbelivable things. We are an Unseen, Unknown, Unvincible fraternity of craftsman.."
    Feb 2012
    Nebraska
    I was hoping to find and fix the problem tonight. Got a busy day to come tomorrow
    In the work truck
    So one of the thermistors is reading off? I dont own that set of pipe sensors but is there any signs the wire was pulled from one of the thermistor? If you jiggle the wire when they are connected does the reading change? I dont think you would be able to repair them if its not a wire breaking.. Im curious to see what others have to say.
    Feb 2012
    Nebraska
    I am reading about 8 k ohms on the low side sensor, open on high side sensor. Also reading open on solder joints going into plug. That tells me the problem is either in the sheathing, or the most likely culprit, at the thermister.
    Not very happy, but atleast its not at the head unit, and I have an extra set of sensors.
    I'm going to build the coolest and baddest set around. Has anyone confirmed the coopers have the same value?
    In the work truck
    yes I use the standard coopers. No major modification needed.. Just soldering the mojo plug.
    Feb 2012
    Nebraska
    She is sending me new ones. I'm still going to make a super set of coops. Maybe 5-6 layers of heat shrink? I want a set I can rope a compressor with lol.
    NW burbs of Detroit
    Seems you guys who use Diggi Queens post more problems with the temp sensors than any other digital on the market.
    My SMAN 3 and Testo 557 and 570 are going strong.
    In the work truck
    Quote Originally Posted by hvaclover View Post
    I knew it was only a matter of time until you showed up. There was no way you were going to miss this opportunity to get a word in...
    Maybe he missed all the testo and Fieldpiece failures while he was bant and those were just the "Clowns" who felt like sharing them here.
    What was the latest one you needed to blow the sockets out with BONE DRY CO2
    I still believe there is hope for Clover. He loves his new BluVac and just needs a Digi-Cool now to complete his zombification LOL
    NW burbs of Detroit
    No Digi Queen for me. Doug convinced me of that.
    NW burbs of Detroit
    BTW, you making fun of my Bone Dry Co2 usage?
    Nope Wish I had some and the small tank you have.
    You could use co2 for leak detection too.
