Results 1 to 13 of 21
Thread: DIY HELP.......
    Jul 2010
    in a service van down by the river...........
    DIY HELP.......
    You Guys are Too harsh towards DIY.... The following is from my favorite Fishing Forum Where the OP needed some quick help. Lucky for him, he had the foresight to go right to his fishing buddys for some top notch troubleshooting. He is cooling down at the moment. Next time you get stumped, don't waste your time here. Go directly to your favorite Fishing Fourm and you will be on your way in no time...................................lol
    OP= Just had a power surge and the A/C is blowing warm air. I reset the main breakers on both the outside and inside units, is there anything I can do without having to call a repair guy?
    Responder #1= Good chance it blew your capacitor.
    Responder #2= is your outside unit coming on...if not you may have fried your start/run capacitor? Check it with a ohm load. It can overload if the fan motor pulled to much of an overload. Try to push the relay switch in manually and see if it will "hard" start ,,,,,,,good luck
    OP= The outside fan is running as well as the inside fan but warm air. I turned everything off gonna let it sit for a little while and turn back on maybe that will reset a relay or something. Ill keep you posted thanks for the replies.
    OP= Ok just turned it back on and seems to be blowing cold again, ill keep an eye on it and see if it keeps working. Thanks for the replies.
    Responder #2= kool
    It's All about Heat.............................to a degree
    Dec 2010
    On a Peninsula in NE NC
    Yeah, but I coulda make 2-300$ there. Your fishin buddies just took food off my kids table.
    I give some diy on other forums as well. This just isnt the place, this is for us pro's
    Jul 2010
    Sim-ma Down Na, ........................I found it amusing, You take yourself too serious. look for Humor in things you cannot control...................
    Nov 2011
    Long Island, NY
    How do I catch a striped bass?
    Jul 2010
    Quote Originally Posted by R Mannino View Post
    I would tell you, but Fishing spots and advice are not revealed to those outside the "Circle"........
    PS: Thank You for "Getting It"..................................
    Houston,Tx.
    Quote Originally Posted by under pressure View Post
    Can you tell me how to catch a mermaid with a little tail?
    Tallahassee, FL
    Nothing got fixed though I don't know how you helped him.
    Jul 2010
    Quote Originally Posted by SBKold View Post
    I never said I partisipated in the disscussion, You are on the edge of "Getting It"........ Keep trying...
    Jul 2010
    Sadly, they will not be intrested in your "Little Tail"........rumor has it that Size matters, whatever that means?????????????????
    Aug 2012
    Toronto, Canada
    Nobody helped him at all... Lol he let it sit not knowing it was the right thing to do.... He was just lucky enough to wait till the internal overloads on the compressor cooled down.
    Jul 2010
    Quote Originally Posted by AYservicetech View Post
    We have a WINNER!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Aug 2012
    Toronto, Canada
    Sweet!!! Can I get the mermaid?!?!
    Ohio
    I wasn't going to say anything but this about sums it up.
    I love watching HVAC help threads on other boards totally unrelated to the trade. Some of the responses are down right hilarious. I will usually let them go unless I see some dangerous advice.
    I frequent a bunch of other boards pertaining to my hobbies... I once watched a thread where a guy had a gas boiler that wouldn't stay fired. By the time I got to the thread they had him jumping out every safety on the unit and he said he could smell it burning up, someone told him to add fresh city water to cool it down... I lost it, and typed my response in bold red letters in the hopes that he would see it in time. Lucky for him he did and took my advice to call a pro after telling him what could have happened.
    Fishing advice needs to stay on fishing boards run by fishing pros, HVAC advice needs to be left to HVAC pros.
