Poor tortured Trane. Hope it does not need to be washed today. The condenser coil has to be removed, picked by a overhead crane and washed in a washout bay if so.
Can't stop a Trane.
Is the unit located inside?
Join http://scopeny.org/ Shooter’s Committee on Political Education
The world is full of sheep,try not to join the flock.
Support the Skilled Trades, Don't DIY
Yes sir.
Wow. Now I know why it looks like that. The head pressure must be through the roof.
What is that unit feeding? Is it a Factory?
I have never seen a Rooftop inside only a residental condenser but it had a Hood on the condenser fan to blow outside.
What's with the filter-drier on the ground in the third pic?
It was like a trane treasure chest of failed, spent, used parts when we opened it up. That drier was just shucked out changing the compressor.
Looks like the place needs some water cooled package units.
Places like that usually use gobs of water anyway, so it is typically pretty easy to get water to the unit, and just do an open loop.
The up front cost is higher, but the difference is made up for in reduced maintenance/repair costs, and massive energy efficiency gain, very quickly.
They are not the only ones out there, but Engineered Air can configure units however you want, so that no mods to ductwork or electrical service are needed.
http://www.engineeredair.com
We take care of a papermill and we have two units in each generator room, thank God they are chilled water but they are worked to death. Room averages 140* in summer. They have a package unit that has to be cleaned every two weeks in one of the generator rooms that supplies a office area.
Chilled water is nice where you can do it definitely. A lot of areas are too far away from the outside, water, restricted by overhead cranes, etc... Overhead cranes use linterns because of the environment(filthy and 130-160 air temp) Linterns are too pricy for most inplant break room, bathroom, mcc, or control rooms. Some plants are just too spread out for chilled water. Water cooled condensers are awesome but I guess water can't be piped there sometimes or who knows what other excuse. So they shuck in a package unit because it's cheapest. Not really designed for the environment which in my opinion is one of the worst for these. Maximum filth, never split, often washed by dingbats sporting straight chemical pump up sprayers, high air temps, garbage filled squashed improperly sized ductwork... list goes on and on. They continue to amaze me though. Tougher machines than most would believe.
Proper tools can get that coil cleaned on site,, If they have a crane on site I understand. If not cost of crane U can get Proper equipment,, and not the washers at home depot.
Seen worst locations.
Not the worst unit out there by far. Just bored that day and they are amusing to work on. Thought I'd share
Crane it,, but make sure customer sees the inside when there split. easier sale down the road.
Pictures after would be a great share
Filthy Friday!
New compressor is happy after we gave it a pep talk.
fan motor is a real fighter
Condenser fan grill is almost choked off
I may have to take another shower this week.
we have a resi type condenser unit inside a recycling plant feeding engineering office. we just put one inch poly filters around it and change it whenever needed. it works pretty decent.
Have tools and gauges, will travel.
RIDGID|YELLOW JACKET|UEI|TESTO|STANLEY|CPS|VETO| KLEIN|MILWAUKEE|MASTERCRAFT|
