    Aug 2009
    colorado
    Question can mastic (pookie) mold?
    Im curious. im working in a hospital remodel and the submitals call for 2 part hardcast on the outside of the duct only. I have done hospitals before and this was never an issue. im wondering if anyone knows if doing this is legit or just overkill?
    Fort Worth, TX
    If the submittal calls for two part hardcast, that is what I would use. The hospital may have reasons for wanting that spec and it is assumed the contractor or installer will merely comply. There may be regulations the hospital must follow that may not have been in effect during your prior hospital work.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Aug 2009
    colorado
    Of course it will be done to specs.
    Quote Originally Posted by Shophound View Post
    Im one of those that want to know the ?why? Thanks for the input though.
