Results 1 to 13 of 15
    Jan 2012
    Vacuum on package unit
    Doing start up on 2-10 ton package unit this is my first package unit start up do I need to pull a vacuum?
    NJ
    What are you going to pull a vacuum on? The system should already be charged and there is no field installed lineset.
    Jan 2012
    That's what I figured but wanted to be 100% sure
    Southold, NY
    Quote Originally Posted by Bigpapi08 View Post
    Try downloading the manual for these units and study them. There’s a lot more to a start up then pulling a vacuum!
    Moved thread to Tech to tech commercial
    Nov 2007
    connecticut
    Ask for factory start form.
    Nov 2007
    connecticut
    Start should be performed by somebody a lot more familiar with equipment
    Jan 2012
    Quote Originally Posted by hapomodi View Post
    have to learn at some point. did fine wired in heater, and performed start up successful. have 4 more to do.
    bigpap
    some important things
    phase rotation
    phase imbalance
    tighten ALL connections
    remove shipping brackets
    check fire smoke detectors if 5 tons or bigger
    Palmyra, Missouri, United States
    check belt, prolly loose and rubbing on one side of shiv.
    The Hot South
    If you have to ask this question, then your probably not qualified to do the startup.
    I know you have to learn at some point, but you should have an experienced tech be with you and teach you on your first startup.
    The Hot South
    I know you have to learn at some point, but you should have an experienced tech be with you and teach you on your first startup. It's not fair to the customer.
    East of big city prices.
    Good grief R123 you don't have to put the guy down twice !!!!!
