Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Apr 2005
    new jersey
    I would advise replacing the flex with steel!! What if this stuff fails.How you gonna replace it.
  2. #28
    leland nc
    just saw the vidio. Looks like the typical nc system. Looks like you may have a damper zone system from the control on the furnace.
    you would IMHO do better and save more by ripping it all out and run two main trunk lines with flex take offs as short as possible to the registers
    you can then bax in the trunks if you like
    that nightmare srider system should never have passed inspection IMO
  3. #29
    Oct 2010
    Quote Originally Posted by tinknocker service tech View Post
    X2, I hate spiderweb duct systems, sometimes you have no choice but most of the time it can be ducted with trunk lines.
  4. #30
    Aug 2012
    it's not a zoned system.
    I might replace the flex with sheet metal tube before it gets mudded up.
  5. #31
    Rochester NY
    DOE/Steven Winter Assoc has recently completed a study and built standards for spray foam insulating duct in attics. I attended a webinar where the author, Bill Zoeller presented their findings. It was fantastic:
    http://bit.ly/sprayfoamducts
    Early adopters will need to be significantly involved in the process to insure quality, probably having to lead the contractors until these strategies and best practices for implementation trickle to the field.
    Attachment 327661 Attachment 327671 Attachment 327681 Attachment 327691
    You can encapsulate unburried duct. It doesn't meet Challenge Home requirements so you wouldn't design this way, but apparently is a significant improvement for retrofit:
    Attachment 327701
    Here's my spray foam picture album for those interested.
  6. #32
    Dry as a bone Tucson
    I have done it for a few customers. The best time to have it done is during a major remodel. On one job the customer added 600 square feet and we reused his existing heat pump.
    Watchman Nee
  7. #33
    Quote Originally Posted by newstudent View Post
    http://i1201.photobucket.com/albums/...C/smith040.jpg
    Spiral is my choice on the round stuff.Flex should be minimized as much as possible.
    Watchman Nee
