    Use of vapor absorption 'heat pump' as a vapor absorption 'refrigeration' machine
    Dear All,
    I have vapor absorption refrigeration machine to cool the water to 10 deg C for the process cooling. If I want to cool further whether I can use vapor absorption 'heat pump' as a vapor absorption 'refrigeration' machine? Please guide me.
    Regards,
    Harshad Katre
    Southeastern Pa
    Quote Originally Posted by harshadkatre View Post
    Dear All,
    Regards,
    Harshad Katre
    Guidance:
    before discussing technical matters, we vet you with a Pro membership. Get your post count up to 15 and submit the Pro membership application, then you can ask your question in the Pro areas, which are not indexed by search engines.
    Thanks.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    up in the hizzy
    Dear All,
    Regards,
    Harshad Katre
    water source heat pump would cool the water up to 30 degrees lower depending on the gpm.
