Thread: Staefa Talon
    Staefa Talon
    Do you need start-up/commissioning tool to set up new talon VAV boxes on a Talon system, or can you use Niagra AX?
    Massachusetts
    You can configure everything in AX. To be more productive you need Staefa templates. The templates allow to configure everything through the graphic interface.
    Jun 2011
    Edgewood, Wa
    We install Honeywell AX equipment. I have a customer with multiple R2 panels with STAEFA Predator controllers. The Customer wants to upgrade to AX. Will a Honeywell branded AX panel work? Is there any JAR files (proprietary) which may cause us problems?
    Feb 2007
    Helena, Montana
    There might be some programming in the R2 that will have to migrate, but it upgrades fairly easily.
    Don't worry zombies are looking for brains, you're safe...
    Jul 2010
    Denver, CO
    I would program the Talon VAV's using WCIS. It seems to go a lot quicker for me, I usually just program them as I walk around with the air balancer. Piece of cake, takes less than 5 minutes per VAV.
    I can give you this program if you want it. Its free.
Comfortech Show Promo Image
Comfortech365 Virtual Event
