    Michigan
    Here's what I have bldg.A Ilon100 and 20 controls working great.
    need to install on there network bldg.B 10 controls what I was thinking was loytec L-IP?
    there are 20 bldg's total that will be on this system just looking for the best setup.will need to bring all into one graphics program.
    would this be a good setup or should I look into some other way.
    all and any input would help
    thanks
    SoCal
    I'd use the optional IP-852 routing in the iLON100 for building A and get another iLON100 for building B with the same routing option. You have to buy the IP-852 licenses but it still might be cheaper than two Loytec IP routers. There is a slight learning curve using the Config Server software to set everything up - but we're here to help!
    Cheers,
    lb
    A hundred million nodes - it's a LON story.
    Feb 2005
    Which graphics/frontend program are you gonna use?
    May 2002
    I would think the ilon......
