Results 1 to 7 of 7
Thread: Nordyne pressure switch ordeal
08-23-2012, 09:01 PM #1
- Aug 2003
- 418
I started a a/c install 3 days ago furnace is a nordyne kg7tc 2-stage that was installed 3 years ago with no issues.While do the low voltage wiring with new stat i deside to start furnace and check operation.status light is telling me pressure switch error so i take the tube off of inducer and work pressure manually through the tube and it closes i put tube on inducer furnace fires i cycle it again and it fires,today i go back to finish a/c install and i have the same issue.the furace will fire only after i blow in and out of the air tube connected to the inducer and its not the condensate switches either so what could cause this other than a replacement switch.
08-23-2012, 10:28 PM #2
Which error - PS Closed Fault, or PS Open Fault ?
If the switch is closed because it failed to open on previous shut down, then I would say it is probably a bad switch.
If the switch failed to close after the inducer started, then it could be anyone of the following :
- Blocked Vent
- Undersized Vent
- Water in Pressure Switch Tubing
- Cracked Pressure Switch Tubing
- Inducer not Running at Full Speed
- Bad Pressure Switch
- Blocked Heat ExchangerInstead of learning the tricks of the trade, learn the trade.
08-24-2012, 06:29 AM #3
Is moisture getting into the hose.
08-24-2012, 07:25 AM #4
- Aug 2003
- 418
I did take all the hoses off and made sure nothing was inside them,the furnace did cycle two times and then three days later i have the same pressure switch error.
08-24-2012, 11:26 AM #5
Answer Rundawg's question and you may get a useful reply. Is the switch failing 'open' or 'closed'?
08-24-2012, 09:52 PM #6
How's the venting? if its borderline you can get intermittent shutdowns. Pressure at tap when furnace starts vs pressure switch setting?
Col 3:23
08-25-2012, 11:16 AM #7
- Aug 2012
- Hot Springs, Arkansas
- 46
I had one do something similar after a thunderstorm. It screwed up the circus (yes I said circus) board.
