Results 1 to 8 of 8
    berlin,maryland
    triangle tube boiler with solar hot water in a basement
Size:  58.3 KBName:  t-bolt 175.jpg
Size:  46.6 KBName:  t-bolt 200.jpg
Size:  45.2 KBName:  t-bolt 201.jpg
Size:  34.1 KBName:  t-bolt 204.jpg
Size:  51.0 KBName:  t-bolt 205.jpg
    be honest to yourself and your clients
    Jun 2002
    south jersey
    Very nice pipe job. Can you explain how it works. Have you ever been in a situation wheree you wish you didn't use pro press?
    berlin,maryland
    The king span solar is the primary heating source for the 80 gallon indirect water heater. Tank is kept at 180 degrees and mixed down. The boiler backs up domestic and does all of the baseboard heat
    I have not had a single leak on the pro press fittings. Fittings do cost about 30% more but you will make it up in time.
    Aug 2008
    levittown, pa
    Very nice install!!! What are you using in the pressure relief valve?
    berlin,maryland
    That is some of the stainless steel solar
    piping I had left. It is expensive but can handle the temp, figured waste wasn't in my vocabulary
    May 2012
    Upper Michigan
    Nice job looks cramped for space like usual.
    Nov 2008
    Seattle
    Triangle Tube Solo 110 with Evacuated Tube Solar
    I have a Triangle Tube Solo 110 boiler with indirect hot water tank. I also have a Thermomax 20-tube solar hot water panel that preheats my domestic hot water in a separate tank. The two hot water tanks are in series. The system has been in place for almost four years with no maintenance required. Eventually, I expect I will need to replace the antifreeze (food grade). The preheat tank is typically heated to about 150 to 160 F most of the summer. Fall and Spring, it will be heated to about 100 F. I live in gray, cloudy Seattle and in the winter, the preheat tank will be about 70 F, which is ambient for the room the tank resides in. Water enters the house at about 48 to 50 F. I am very happy with the system. The one lesson I learned is you MUST have a preheat tank to capture maximum solar btu's. Otherwise, the system would not operate on the many days it could not heat above the domestic hot water preset temp (120 to 130 F).
    Name:  Triangle Tube Solo 110 w Indirect Tank.jpg
Size:  121.7 KBName:  Pump Station and Controls.jpg
Size:  84.0 KBName:  Pre-Heat Tank.jpg
Size:  71.4 KBName:  Thermomax 20-tube panel.jpg
    Sep 2012
    thomaston, ct
    Sweet Job. Why not paint the board though?
