Results 1 to 8 of 8
Thread: 2-Stage Stat
08-23-2012, 11:58 AM #1
- Aug 2012
- 21
2-Stage Stat
I'm having a system installed tomorrow, and would like to know how I can tell if a 2-Stage stat is installed.
The Contractor said they are installing a VisionPRO® 8000, but when I look online I don't see anything that tells me.
08-23-2012, 12:17 PM #2
Professional Member*
- Aug 2012
- willowick ,oh
- 165
The thermostat that you are getting has many different capabilities depending on the system that you have. If you have a heat pump chances are it is 2 stage. Just ask the contractor to show you the sub base of the stat and to explain how it operates
08-23-2012, 12:18 PM #3
All visionpro 8000 are at least two stage.
08-23-2012, 05:54 PM #4
08-24-2012, 02:47 PM #5
08-24-2012, 02:49 PM #6
8320/8321, needs to be properly wired on both ends and installer needs to go to advanced setup and ask for 2 stage operation.
08-24-2012, 09:02 PM #7
- Aug 2012
- 21
I just had my system installed with the TH8320U1008... I didn't notice him doing anything special with the stat (he might have), but when I asked if there is anything special I need to do with regards to 2-stage operation, he said no... he programed the furnace and Stat, and it will take care of itself automatically. Is this how a 2-stage stat works... set it and forget it? How can I tell if it's setup correctly?
08-24-2012, 09:17 PM #8
Once set up, there is nothing special you need to do. To tell if its controlling the stages of the furnace. Set it 1 degree warmer then the house temp, let it run for a few minutes. long enough for the air to be warm coming out of the registers. then set it 5 degrees higher, and see if the blower increases in speed.
