Results 1 to 13 of 28
    Aug 2008
    Find the Problel 8/2012
    10 Ton Trane Pkg Gas Rooftop Install 208/230 V 3Phase
    Is that green wire a ground ?
    Sent from my SCH-I800 using Tapatalk 2
    Aug 2008
    Hmm NO!
    Looks like the line side wiring is undersized, in the pic it appears to be 10ga wire. Should have been at least 6ga wire going to that terminal block.
    When you do a job, Always make it easier for the next guy, because you may be the next guy working on it.
    Aug 2008
    It is at least a 6 may be a 4.
    Oct 2011
    Chicagoland Area
    That's what they call a single phase conversion. Attach the green wire to the terminal block and it becomes 3 phase.
    May 2011
    Western, KY
    There's a mess in the bottom left of the screen I cant make heads or tails of and it looks like one or more wires have the insulation tucked under the screw.
    Jul 2009
    Columbia, MD
    its 208 volts and the tap on the transformer is at 230
    i was also seeing the insulation under the screw
    Sep 2010
    Western, MO
    Not sure if the middle leg got pushed in all the way. And why are there jelly fish swimming just below the terminal block?
    jim
    Common sense isn't very common anymore.
    Aug 2008
    10 ton 208/230 v 3 Phase Trane gas Pack. The Green wire is used as a HOT Leg of Power. And There is not a proper Ground to this unit. To top it off this is located on the "Former City Hall" Where the Inspectors office was at the time of install 10 years ago.
    Atlanta GA area
    Quote Originally Posted by AC Shop View Post
    Classic!
    Inspectors are NOT about safety, they are about an easy income... Actually, to a degree they seem to have an entitlement mentality (like everyone else on the govt dole... payroll or non-working).
    Ga-HVAC-tech
    Beware the Dunning-Kruger effect
    Sep 2006
    Burnaby, BC
    Got a little warm at one point, did it?
    Please excuse me if my post looks like it was typed by a teenager. It was sent from my phone.
    I do three kinds of work.
    1 - Good - 2 - Fast - 3 - Cheap
    Pick two
    Oct 2011
    Cicero, IN.
    Electricity does not care what color the wire is.
