Results 1 to 13 of 29
    May 2012
    California
    Trane RTAC and oil samples
    Anyone ever experence high moisture content in oil samples from 134a systems. Samples have been taken on machines that have not ever been opened up from factory. Second question why does Trane not put driers in there RTAC chillers any ideas.
    Jul 2012
    Southwest
    So my RTAC 250 drier shell is a strainer only? How old is that RTAC?
    Quote Originally Posted by JEF1980 View Post
    ...Second question why does Trane not put driers in there RTAC chillers any ideas.
    I know that they do put driers in there...maybe they have been opened up.
    May 2012
    California
    I'm going to take samples agian in glass sample botttles. Maybe POE is picking up moisture through the plastic bottles. We are positive that it has never been opened up. Does anyone know the reason for no driers are they thinking that the oil is so hydroscopic that it would pull mositure if there is any from driers anyways so no point in putting them in. Just thinking.
    May 2012
    California
    @ B1978 yeah they are a paper element everyone i've seen are like this.
    A land down under
    What moisture content are you seeing and more importantly what is the TAN?
    The attached will answer you questions concerning the use of drier cores.
    Attached Files Attached Files
    Aug 2009
    Prattville, Alabama
    Interesting document, Screwit. Thanks for sharing. I'm curious, where did you get that?
    Mar 2010
    Va.
    A land down under
    No problems Nuclrchiller, came out of Europe at the time of the RTAC/ RTAD/RTWB release.
    Aug 2009
    Prattville, Alabama
    Quote Originally Posted by Screwit View Post
    I was still at Trane at the time, but I don't recall ever seeing that over here. That explanation is simple and to the point, the way I like it.
    May 2012
    California
    Thank you
    Feb 2012
    EVERYWHERE
    There is not much need for a oil sample in a air cooled screw with POE oil. You are only looking for acid in the oil and yes the POE does pick up moisture through the plastic bottles. It is better to just do a acid test.
    Quote Originally Posted by FixItRight View Post
    oil samples do more than just look for acid or moisture. they also look for wear metals. as for the acid test, that is a Pass/Fail type of test. an oil sample will show you the acid level and over time, you can watch it rise and make decisions before it 'fails'.
