Thread: Flow Hood
    Apr 2012
    Millsboro, DE
    Flow Hood
    So I'm thinking about retiring my Alnor (analog) Balometer that's older than some of you reading this (I may have used it a couple of times a month over the 20-odd years I've had it). I need a 2x2 to read from less than 50 CFM to as much as 1,000 CFM or so. Lighter weight would be nice, but I'm not too "electronic", so memory, etc. is not important. I'd appreciate any suggestions. Many thanks!
    Oct 2010
    I use the alnor lowflo bolometer it reads down to 8cfm but I think it only goes up to 500cfm if I'm not mistaken. It works great for what I use it for, airflow trouble calls and energy audits
    You will need at least 2 different balometers to cover the CFM range you want.
    RSES Certificate Member
    RSES-SWRA President
    May 2009
    South of Heaven
    Apr 2012
    Millsboro, DE
    T45: The Shortridge CFM-88L looks like what I need, thanks. By any chance, do you know who sells it at the best price?
    May 2009
    South of Heaven
    I'm not sure who has the best pricing on these.
    Shortridge is the instrument that all of the TAB contractors I've worked around seem to use. Im sure they are not cheap , but fast and accurate for sure.
