Results 1 to 7 of 7
    Dec 2006
    Massachusetts
    York YTG optiview
    I have a York YTG with optiview panel. the screen went blank last week. In checking it out, the screen came back but now fails the mini flash card checksum test everytime it boots. I can't find any info on this or what to do about it. any help out there is greatly appreciated!
    Jan 2011
    You need to apply for Pro Status. I won't go into step by step troubleshooting in the open forum. I would consider replacing the flash and the bios eprom...may or may not solve your problem, but the alterantive is considerably more expensive.
    Dec 2006
    Massachusetts
    alternative being microboard i presume?
    Jan 2011
    Yes, and the old version 031-01730-000 is no longer available. The replacement is 331-02430-602.
    Dec 2006
    Massachusetts
    thanks for the info
    Tijuana, Mexico
    Check all the J1 terminals.
    Jul 2012
    TX
    I had the same problem in a plant which had a less than hospitable environment (air quality wise). After troubleshooting all the connections, I removed the flash card and gently blew out the socket with canned computer air. I did the same with the card. I then replaced the flash card. Some in this place do not securely close the panel door.
