Page 5 of 10 FirstFirst 12345678910 LastLast
Results 53 to 65 of 125
  1. #53
    NW burbs of Detroit
    Looks like we got a Jedi Duel over com analyzers.
    Both these guys are masters at their craft. Let's see if there is a definitive first place finisher.
  2. #54
    Apr 2012
    Cleveland
    Quote Originally Posted by Jim Davis View Post
    Testing light-off on gas furnaces is a waste of time if you don't care about:
    1. misaligned burners
    2. dirty burners
    3. defective or misaligned ignitors
    4. leaky gas valves
    It didn't explode so that's okay with me, just isn't good enough!!
    What will a combustion analyzer tell you about these. Are there acceptable start up levels or what?
  3. #55
    In a boiler room
    Quote Originally Posted by Hvac216 View Post
    A combustion analyzer will tell you all that and more. But only if you know what the numbers are telling you. I highly recommend Jim Davis' 3 day class. You will be amazed at what you've been missing.
  4. #56
    Apr 2012
    Cleveland
    Quote Originally Posted by chuckcrj View Post
    I took a class a couple years ago and know a lot of what it can do. I just don't know how you check those points with an analyzer. I will definitely check out the class. It sounds good.
  5. #57
    Jul 2009
    Columbia, MD
    yup....DAMN i can tell you about all those things too
  6. #58
    there was a reference to CO(O) in the 3 bar graph section, but it was CO in the trend graph.
    which is the one that is more important, that is to say the below 100PPM in flue is acceptable?
    CO(O) is reference to your outside or start up air location, 20.9%.
    CO is the flue gas measurement- total CO produced, correct?
  7. #59
    Westlake, Ohio
    Quote Originally Posted by pacnw View Post
    What you actually measure is always more important than what the analyzer calculates. CO "as measured" less than 100ppm is good.
    captain CO
  8. #60
    Westlake, Ohio
    Quote Originally Posted by hvaclover View Post
    My hope is you guys finish first but I will never recommend anything that I consider sub-par just to make a sale. Many times over the years, even when I was a commission only salesman, I told customers if they were convinced they wanted to buy a certain item I felt was not in their best interest, to buy it somewhere else and don't call me and complain if they do. They called and complained anyway and said I wasn't convincing enough?
    captain CO
  9. #61
    The Zone
    Insite is allright, have both the 327 and insite.
    It's Hammer Time!
  10. #62
    Jan 2005
    Akron
    Both Bacharach analyzers respond to CO much faster than the new Testo's. O2 about the same.
    Not exactly what I saw when I tested the units.
    Obviously, you have to consider that the Intech was influenced by prompt NOx at light off because it does not have a NOx filter (optional accessory). The Testo 310 and the Insight plus both have NOx filters and read almost exactly the same, and saw about the same peak CO. They are all three good analyzers. The fixed probe on the Testo is not a big deal due to the short gas path. It clears out quickly. The 310 also has a 4000 ppm sensor.
    JLB- Co Owner TruTech Tools Inc.
  11. #63
    Jul 2009
    Columbia, MD
    nice video
  12. #64
    5,000 ft
    Both Bacharach analyzers respond to CO much faster than the new Testo's. O2 about the same. 310 Testo needs to be avoided. The InTech is a nice inexpensive unit, around $700, we always include a Dwyer Draft Gauge. For extra $$ you can get Software and printers etc. but that is the same with both Bacharach and Testo.
    Good info Jim, almost ready to buy the Testo 320. I want to get something new before the season hits hard. My TSI does have a new sensor though. Could keep it for back up. I think the pump is ready to go as the response time on the readings seems to be longer. Not sure how much longer parts will be available for the discontinued TSI.
    I didn't even consider the Bacharach since I thought they had "older" technology than Testo. Worth the look before I put out the $$.
  13. #65
    5,000 ft
    Jim B. Thanks for the videos!
