Results 118 to 127 of 127
Thread: combustion analyser
12-20-2012, 02:42 PM #118
- Dec 2005
- Mechanicsburg PA
- 215
I took out the pump but couldn't figure out how to get it apart without breaking it. Is there a way of squeezing it to separate the halves?
Arizona dreaming....
12-20-2012, 09:41 PM #119
There are four legs that snap into the end of the pump. You have to stick a heavy paperclip in the hole in the end and loosed one side carefully and then the other while trying not to break the tabs. It is simple once you do it. Worst case send it to me and I can fix it.
captain CO
12-23-2012, 09:18 AM #120
- Jan 2007
- pittsburgh
- 342
12-26-2012, 08:31 AM #121
12-31-2012, 08:43 AM #122
- Jan 2007
- pittsburgh
- 342
12-31-2012, 01:14 PM #123
01-01-2013, 11:09 AM #124
- Dec 2005
- Mechanicsburg PA
- 215
Thanks. The pump came apart easily. I saw no dirt or any other problem with the diaphragm or reeds. I put it back together and now it works fine. I wonder what I did that fixed it.
Thanks again for your help.Arizona dreaming....
01-10-2013, 09:00 PM #125
Has anyone had to change the thermocouple on the 327? Mine stopped working new one arrives Monday.
Yesterday, 01:06 PM #126
- Nov 2012
- Charlotte, Michigan 48813
- 50
I bought a used Fyrite Pro 125 on the net before reading this thread.
Is the slowness of the pump the only reason why they aren't very popular here?
Would it be a good tool for a DIY to make sure his propane furnace isn't underfired?
If the O2 sensor is dead, is it worth fixing?
Yesterday, 02:20 PM #127
The fyrite pro is now obsolete. The slow pump is a problem in some cases but unless you are testing oil it is okay. The O2 sensor is about $160 and you just install it yourself. I would say it is worth it to fix if everything else is in good shape. CO sensors last up to 10 years but do need to be calibrated or checked every year.
captain CO
