Results 14 to 25 of 25
    Still waiting to hear what the unit is?
    Aug 2012
    Model Number of unit.
    Thanks folks,
    Yes the unit's a 13AJN30A01 Value series. I wanted to keep it simple.
    So..... Basically if it's not broken don't mess with it.
    I do preventative maintenance on the unit, which includes cleaning the condenser and removing debris at end of the cooling season. A fin comb to straighten fins if needed.
    Then cover the top with a piece of plywood on stand-offs so the box can breathe.
    On a second note: When a systems not running (static), is all the refrigerant in the vapor/gas state? And only becomes liquid after compression and cooling in the condenser pipes? Or does some of the refrigerant stay liquid when the units off?
    Again I thank you all for your replies.
    Joe.
    Aug 2001
    Pavilion, NY
    The helicopter noise is due to
    The manufacturing design of the unit. I'll let baldy elaborate ( don't want to steal his thunder)
    Aug 2012
    Additional infractions may result in loss of posting privileges.
    Go for it KGod. Glad to see someone besides me knows what the problem is with those units, the 2.5 ton is worse. But you won't stop the chopper sound, sorry
    Aug 2001
    Pavilion, NY
    Aug 2001
    Pavilion, NY
    Looking from the top down you will see that air enters the sides, is drawn through the coil and out the top. You will also notice that 1 side has no coil and is blanked off. Another side has 1/2 a coil. Air is drawn through 230 degrees of the coil And 150 degrees of the coil has no airflow. As The blade hits the dead spot it chops the air and you will have noise.
    lsu4life
    Aug 2012
    Thanks Folks,
    It looks like Rheem uses the same box for the 13-seer 2.5, 3.0 and 3.5 ton units.
    Just adding more coil area, fan and compressor size as needed.
    Simplifies the amounts of parts needed on the assembly line.
    But it does leave blank areas on the smaller ton units.
    Joe.
    Jun 2001
    Is the fan a 1125RPM or an 850? The 850's tend to be much quieter but are normally on the higher SEER units.
    Aug 2012
    Quote Originally Posted by 54regcab View Post
    The fan motor is a 1/6 HP 850 RPM type, if you still wish to know.
    There's only about a million posts on this site and any single one can get lost.
    Hello, Hello, anybody out there????
    Joe.
    Jun 2001
    I have the same 2 blade setup on my condenser, it's very quiet. I'm thinking dirty condenser is your issue.
