Results 1 to 8 of 8
    Mar 2012
    Amer. Std. / Trane condensor coil guard issue.
    I have an Amer. Std. Heritage 15 heat pump that has started to develop quite an annoying noise. The outdoor metal front louvered condensor coil guard is vibrating slightly back and forth when the fan is on. It is definitely because of the air flow not the compressor. The left,right and rear covers do not vibrate at all. If I press on the cover in the middle of course the noise will stop. Has anyone ever seen this before? If so is there a fix? Service bulletin?
    Anderson SC
    Tighten the screws?
    willowick ,oh
    cork insulation tape
    Mar 2012
    Yes, all screws verified: nice and tight.
    Dec 2008
    Buffalo NY
    How did you tighten them? Did you use a screw gun? Seen many sheet metal screws striped out that way.
    To the man who always did it right. I love you dad and I will miss you to much for words.
    Stay Thirsty My Friends
    Support the Skilled Trades Don't DIY
    Mar 2012
    Verified by hand to make sure they were snug. The issue is it is vibrating directly in the middle. I noticed it is hitting a black stand off. Also I noticed these stand offs are located on three sides except the inspection side. They look as if they are used to prevent the metal guard from crushing the spine fins. Anyone know about these plastic standoffs?
    Anderson SC
    The coil is not as close on the control side do standoffs are not necessary on that side. It is pretty common for coil guards to make a racket. I thought the service guy was the only person it irritated. Usually I just "tweak it" til it stops. Don't know how long my " tweak lasts but it's long enough for me to move on to the next one
    Dec 2008
    Buffalo NY
    Quote Originally Posted by Unclev View Post
    I follow you now. Try placing some foam tape on the standoffs. That should stop them from vibrating.
