Results 1 to 10 of 10
    Educational software
    hello everyone, this is my first post and I am in need of HVAC training software
    (residentail and load calculations) any suggestions would be greatly appreciated.
    regards
    Jul 2000
    Guayaquil, EC
    Welcome to HVAC-Talk
    Join in some forum discussions, introduce yourself and get you post count up so you can apply for Professional Membership:
    Once you get Pro status, you will have access to the Educational Forums which contains tons of links to HVACR info and articles.
    Thanks, I will work on that! I was out of pocket in the HVAC business for some years (1990’s) and I was looking into some software to educate myself while I attend trade school. My goal is NATE certifications start a mechanical electrical contracting business (semi retirement).
    Thanks again for the info, Nappy.
    May 2012
    Nanaimo BC
    Does anyone know of any HVAC simulations that are available online for free or purchase? a tablet app would be nice.
    Sep 2012
    software for ductwork design would be awesome
    Nov 2011
    cool pack, will be Good, is most have for all RAC technicians.
    Mar 2013
    Please tell me, "what is the best method for doing heat gain/loss calculations on homes with open floor plans also open to 2nd level. We do a lot of these types of homes and they always seem to present a little more of a challenge"
    Mar 2013
    Quote Originally Posted by Bridget21 View Post
    Any comments?
    aged care toowoomba
    Jun 2013
    NORTHERN
    Before manual J fit the loads for GeoThermal loops to meet a 24/7 running system and a loop entering above performance contracting of 34*f, we used the one that Solstar Solar came up with, and since then houses only got tighter.
    It still works for most of what you desgribe to also look at if the home still had an 8.1/2-9 ft room height- and vaulteds as then 2 stories (smaller second).
    even near KY line (57 deg ground water map lines from the cep of nat resources)
    hihg return airs pose more run time for cooling but then dries the home more so too, a practical efficiency with cellulose insulated- breathing homes without ervs to 5000 sq ft or more... I have reason to believe.
    A 3- 3.1/2 air volume change thru a heat pump or high eff air works well with high returns.
    Variable VFD Compressors in GT and others works great to that calc at the very highest speed, alleviating 3 and 4 significant figure calculations as some companies VFD's are 3t 4.1/2t and 5.1/2 to 6 t, by comparing to other AHRI ratings
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    ANY MANUFACTURER WILL BE GLAD TO SEE YOU THROUGH ALL !
    (then , maybe, a manual J)
    Jun 2005
    mississippi
    try mylinkdrive.com for Mitsubishi software
