    Bad allergy need help on how to reduce
    Mold is high on allergen count
    What is the best way to help reduce that indoor?
    Also mountain cedar is around the corner. When that is high, I usually suffer the most
    How can I reduce that.
    Will UV help with mold allergen?
    How about mountain cedar?
    Any help is appreciated
    Anyone?
    Please don't respond all the same time
    I have aboUt 2 pages of things I'm allergic to
    Buch of diff pollen
    Grass,oak,elm,mold
    Especially mountain cedar
    I'm not up to date with all these Uv light
    So learn me about air quality
    I'm a good listener and great student.
    IM DYING Y'ALL .
    NE wisconsin
    What are you currently doing to clean the air? Is it an older home, fresh air intake on the duct work or an energy recovery ventilation system? UV light alone probably won't fix the problem. For severe cases it usually takes a combination of better filtration both on the air handler and on fresh air intake, UV and ozone light, and if mold is the issue possiblely dehumidifier. It's kinda hard to make recommendations from the other side of the country not knowing what exactly the whole picture is, might do well to get a consultation from your favorite local HVAC tech. Good luck any more questions just ask.
    Apr 2012
    winnipeg
    lennox pure air will help..... trane also has a good one.... there are many
    Rochester NY
    Air seal the house, 4-5" media filter, run low fan 24/7, run house positive pressure...
