Results 1 to 12 of 12
    So. New England
    I have to bang on compressor to get it going
    Quick question about my ac compressor. I lower thermostat & can hear the air handler come on. Great, house should be cool soon enough. But it's not. Look out window and the compressor isn't running. I go outside and bang on it (figured it's worth a try) and it starts running.
    Now this happens if the A/C isn't used for a few days. Please help with any suggestions.
    Thank you so much, Michelle
    Fort Worth, TX
    Call for service. Could be any number of things inside that unit responding to your bang.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Dec 2003
    Citrus County, Florida
    Use a rubber mallet so you don't hurt your hand. Or you could call a servcie tech. There are a multitude of items that could cause this.
    Doug
    Massachusetts
    Use your head, not your hand! You could have a problem that is doing cumulative damage when the unit is trying to start and doesn't. A smart person would have already called a pro for service. Are you smart?
    Athens, Ohio
    What you are hitting is not the compressor. Hitting a compressor won't help it start. Call a pro to find out what is not working and let him do what needs to be done.
    Athens, Ohio
    Quote Originally Posted by skippedover View Post
    x2
    Apr 2012
    winnipeg
    really.... bang it... and you want help.... not much to go with there....
    Nov 2001
    east kansas
    Reminds me of my first house and furnace. The heater would not work until I banged on the little gray box. I'd have to do that several times then the furnace would work fine for the rest of the year.
    I also remember the blower motors running all the time after the furnaces would shut off. I was "taught" to smack the side of the furnace and it the blower stopped to just replace the fan switch.
    So what might be happening when you hit your unit is you are helping a switch make good contact to pass power to the rest of the parts. You will need to call for service.
    Beware of advice given by some guy on the Internet.
    Apr 2012
    winnipeg
    indeed
    I would just go beat the crap out of it mabey it will keep working
    NW AR
    I think were supposed to help these people, not make fun of them.
    It sounds like a very simple fix but it will have to be performed by a pro. The longer you wait and/or keep beating on the unit the more likely the problem could turn into bigger money. Good luck
    Apr 2012
    winnipeg
    I agree
