Results 1 to 13 of 20
08-17-2012, 09:47 AM #1
- Aug 2012
- 8
Can I Vent My Boiler Over My Neighbour's Driveway? (Toronto)
I'm looking to replace my boiler and I need some advice. I'm in Toronto, in an older (1940s built) house. My house sits on my neighbour's property line. My current boiler vents up the chimney, but I'd like to move to sidewall venting to reduce potential CO issues.
See pictures (x3): http://imgur.com/a/u0gew
Some contractors told me that the best solution (based on space constraints) is to vent onto/above my neighbour's driveway. But according to CSA B149.1-05 section 8.14.8 "a vent shall not terminate directly above a paved sidewalk or paved driveway that is located between two single-family dwellings and serves both dwellings". Granted, the driveway does not serve BOTH dwellings, but I don't see why it suddenly becomes okay if it just serves one.
My question to you guys: Can I legally vent onto/above my neighbour's driveway? Based on the pictures I provided, do you see a potentially better solution?
08-17-2012, 09:58 AM #2
Professional Member*
- Aug 2008
- Burlington , Mass
- 443
Why cant to have a chimney company install a liner in the existing chimney ? Is looks like your chimney is outside the home ? A liner would sure help with the draft, and eliminate all mechanical venting.
I'll be there when I get there and not a minute later
08-17-2012, 10:37 AM #3
If you are abandoning the chimney why not use it as a chase to get the PVC pipes to the roof and terminate there?
08-17-2012, 10:52 AM #4
08-17-2012, 12:15 PM #5
- Aug 2012
- 8
The chimney is part of the home, with an external wall.
I assume you mean direct venting PVC out the chimney? The issue is that my HWT is natural draft vented through the chimney and I can't common vent with the boilers I'm looking at (Slant/Fin VSPH-90, Olsen ODV-75B).
If I get a boiler that is natural draft (example Lennox GWB8-112IE), then I have to seal up the boiler room for an extra couple grand.
08-17-2012, 12:46 PM #6
Check with local code enforcement about the regulations of venting over the neighbors driveway. I suspect not, but if it is allowed there will be a minimum height requirement the exhaust will have to be above the driveway. Many considerations here.
When you orphan the water heater, you will need to line the chimney. That money may be better spent on indirect water heater, or direct vent domestic water heater in addition to your boiler.Climate Control Solutions for your Home or Office
08-17-2012, 12:52 PM #7
- Aug 2012
- 8
Thanks. I totally agree regarding calling code enforcement but I did call the TSSA and they told me to review the code with a licensed contractor. That's where I got the snippet in my original post. I also called who I thought were the local inspectors and they claimed not to be able to help me:
http://www.toronto.ca/311/knowledgeb...000032188.html
I'm running around in circles here just trying to get a definite Toronto based answer.
08-17-2012, 12:57 PM #8
I questioned this a while back and was told that if any water drips from the pipe and freezes, then someone slips and falls, the homeowner is liable. We found another way to vent the flue so it didn't run near a sidewalk or driveway.
GO NAVY, BEAT ARMY!
A DECADE OF DOMINANCE! +1
08-17-2012, 02:05 PM #9
Best to combine the water heater with the boiler using indirect ro looking at a wall hung boiler or combi boiler.
08-17-2012, 03:05 PM #10
- Aug 2012
- 8
I'm leaning that way now, but I'm still puzzled on how to vent it. I want to maintain sealed combustion, so I'd prefer not to draw air from inside my home.
I'm specifically looking at the Viessmann Vitodens 100. In the venting manual (link below) it states that I can use coaxial venting. It looks like this provides both intake and exhaust. Can I do this through my chimney? Alternatively, is it okay to use both an intake and exhaust PVC pipe through the same chimney flue?
http://www.viessmann.ca/etc/medialib...Venting_ii.pdf
08-17-2012, 04:36 PM #11
Understand the chimney becomes a chase for the PVC pipes. If the diameter of coax pipe for the Vitodens will fit in the chase all the way from bottom to top, you should be able to do that. Same with PVC. You will use 2 runs of pipe - one for combustion air and one for venting.
This all still needs to be verified by someone on-site that knows your local codes.Climate Control Solutions for your Home or Office
08-17-2012, 04:56 PM #12
- Aug 2012
- 8
08-17-2012, 05:06 PM #13
We do a lot of North Atlantic coastal installs and it's not uncommon for us to find installs done by others using side-wall where the strong winds affect inducer issues, even with sealed combustion. We've solved a number of problems that way by venting up an old chimney, all the way to the top with the exhaust. But due to a lack of space for a 2nd vertical pipe, we've opened the chimney base sufficiently to get the combustion air intake into the bottom of the chimney so it pull fresh air down the chimney, around the exhaust PVC. We've never had an issue doing this, solved several wind problems for customers and made a handsome profit in doing so. I personally have installed old HeatMakers and others with concentric pipes and over a long run, it can be a painful ordeal.
