Results 1 to 11 of 11
    Apr 2012
    Kansas City, KS
    trane t stat is blowing transformer
    I replaced a trane heat pump tsat (Tempcon 602) and i am now blowing transformers. It is going to a dual fuel kit tayplus 103a. I was able to match up the wires correctly except for one the T wire, there is not one for the new stat i thought is matched up to the F wire, becaues the T wire and the F wire were matched on the tstst install driections. The a/c and heat pump is working but the emheat is were the amps on the 24v spiking. any ideas
    thanks
    Dave
    Anderson SC
    No DIY call a contractor.
    tempcon 602?
    sure that thing wasn't a tcont602
    now you've let the magic smoke out (it can't be put back either)
    need to call someone that is capable of figuring out how that t-stat gets wired.
    jt-you gonna get the dreaded message- you aren't permitted to post in any of the AOP forums without a * after your name
    Anderson SC
    I have a * dandy
    didn't notice - never mind then.....
    That t wire gets the best of many people .the t wire is only used on trane mercury bulb thermostats .
    Pro tip: Fuses are cheaper than transformers, and take a lot less time to replace.
    Apr 2012
    Kansas City, KS
    Thanks Im just going to rewire the whole system with a honeywell vision pro.
    Jun 2001
    Moore, Oklahoma
    I've seen the t terminal on Honeywell also. Looks just like the trane branded stat though. In either case we just don't hook up the T at all when replacing with digital. I not sure what T even does, some type of anticipation circuit ?
    Anderson SC
    Goes to thermistor to control cycling in heat for that thermostat
    Feb 2011
    Chesterfield, Virginia, USA
    As stated the "T" wire was hooked to an outdoor thermistor for heating anticipation of a mercury bulb thermostat, just omit it.
