    Aug 2012
    Oil and oxygen don't mix
    I was wondering if anyone had information on an incident that happened I believe in the '70's when a tech was replacing a compressor on a refrigerator and tried to clear the cap tube with oxygen. I remember a slide show showing the results. I am now teaching at a technical college and I wanted to use it for one of my classes.
    Thanks,
    John
    New Mexico
    Quote Originally Posted by GeoJohn View Post
    Thanks,
    John
    I don't have any about that particular event but while in the Air Force oxygen servicing for the liquid oxygen converters covered training about the dangers. When servicing converters they will vent pure oxygen when full. A lot. Spontaneous combustion can occur with no source of ignition. Only close call I heard of was while a system was being serviced the vented oxygen got close to an outrigger and the tech discribed a very strange plume for several seconds. It got his attention.
    Very good to teach of this danger. Maybe because of my AF training using oxygen for anything other than what should be never occured to me.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Atlanta area
    Vacuum Technology:
    CRUD = Contamination Resulting in Undesirable Deposits.
    CRAPP = Contamination Resulting in Additional Partial Pressure.
    Change your vacuum pump oil now.
    Test. Testing, 1,2,3.
    Atlanta area
    Oil, ice, air, and turkey:
    http://www.popsci.com/diy/article/20...tter-fire-bird
    Read the comment below the article which suggests turning off the fire before dropping your bird.
    DO NOT heed the advice of the other comments about deep frying below the article. They were written by idiots who think they know what they are talking about, and who make very stupid assumptions.
    Vacuum Technology:
    Oct 2011
    Chicagoland Area
    If I'm not mistaken, there was a pipefitter here in Chicago quite a few years back who got killed leak checking a system with oxygen.
