Thread: Another Vacuum Setup
08-15-2012, 09:23 PM #1
Three-way air manifold
2 - 1/4" X 3/8" X 3/8" vacuum hoses
1 - 3/8' X 3/8" X 3/8" vacuum hose
3/8" hand valve
1/4" port with shut off for micron gauge and to break vacuum with refrigerant prior to removing setup/putting on gauges
It all fits in that little red back to the left. On a small k-body two door freezer it pulled down to 500 microns in about 10 minutes. Took a half hour lunch and when I came back it was at 320 microns.
Supermarket Tech...and anything else the boss finds for me!
08-31-2012, 10:45 PM #2
- Oct 2011
- TX
- 82
I like that. I could use a set up like that for 3 point recoveries on ice machines. Where did you get the three way valve ?
08-31-2012, 10:54 PM #3
Northern Tools, Lowes also has them.
Sent from my DROIDXSupermarket Tech...and anything else the boss finds for me!
08-31-2012, 10:56 PM #4
you'd be better off mounting that 3 way valve to the pump and eliminating a hose. i would also put the micron gauge on the system side.
08-31-2012, 11:17 PM #5
I might have to check into mounting it to the vacuum pump. I don't want it on there permanently thou. I like the micron gauge where it is.
