Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 74
  1. #40
    Dec 2010
    On a Peninsula in NE NC
    Suction pressures pretty par for orphis header on the evap, I have never seen 1 run 70#suction or above
  2. #41
    Mar 2011
    Long Beach, CA
    Where is the superheat and sub cooling. It will be very difficult to give you an explanation for the symptoms which you are experiencing with both. It takes all of two minutes each.
    Troubleshooting is not part of the repair............understand the symptoms and you will find a solution.
  3. #42
    Mar 2011
    Long Beach, CA
    Where is the superheat and sub cooling. It will be very difficult to give you an explanation for the symptoms which you are experiencing with out both readings. It takes all of two minutes each.
  4. #43
    Aug 2012
    west burbs,il
    After fixing leak on discharge line for circuit 2, vacuuming and recharging with 7.4lbs R22.
    Circuit 1
    Suction: 62 psi
    Head: 275 psi
    Circuit 2
    Suction: 66 psi
    Head: 270 psi
    Return: 84 degrees at all 3
    Supply: 65 degrees at all 7
    Tstat: 85 degrees
    After system ran for over an hour temp in kitchen dropped to 81 degrees, but still felt like it was cooling.
    These were the readings after he cleaned condenser coils and replaced both filter/driers. I know these posts get lost sometimes. I don't believe charge is the problem if he dumped in factory spec, r-22 is pretty forgiving if your a little over or under unlike 410.
  5. #44
    Mar 2011
    Long Beach, CA
    Dude, whats your superheat and sub-cooling. With out this there is no hope.
  6. #45
    Jul 2012
    Everett, WA
    Quote Originally Posted by alcomech View Post
    I didn't get a chance to take note because I got a call cause a grill and fryer were down and needed attention otherwise products couldn't be cooked.
  7. #46
    The Hot South
    Quote Originally Posted by caheiman30 View Post
    Without superheat and subcooling, everything posted is speculation. That should have been taken on your first call and it only takes about 2 minutes.
  8. #47
    Southeastern Pa
    Quote Originally Posted by canusayinsanity View Post
    I have to ask....who is HE? You mean it's not you?
    Who is doing the work.....?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  9. #48
    Aug 2012
    MA
    Got a trane package unit the doesn't wanna cool properly, kitchen area at restaurant is 83 degrees. One circuit is running good, but the other circuit is running high suction and high head pressures.
    Model #: YCD120B3H0DA
    Circuit 1
    Suction pressure: 67 psig
    Head pressure: 315 psig
    Circuit 2
    Suction pressure: 65 psig
    Head pressure: 250 psig
    I am leaning toward circuit 1 being low on refrigerant, but the lead tech says no that the coil is dirty. I have cleaned the coil and it does lower the head pressure for a while but it will slowly go back up.
    You gotta split those coils man and wash em good... Then check your operating pressures.. I have lowered my head pressure from 325 to 250 easily before by splitting those coils...
  10. #49
    Jul 2012
    Everett, WA
    Quote Originally Posted by pecker head View Post
    As I have said before the coil doesn't split, its a single vertical coil that is a double pass coil from what I have read about it.
  11. #50
    Aug 2012
    MA
    ya man one a little grease gets on a coil it becomes a magnet for pollen...
  12. #51
    Jul 2012
    Everett, WA
    I have chemically cleaned the coil on 2 different visits to mess with this unit and it runs lower head and suction for a little while then slowly gets back up. But this store is due to be moved to another location with all new equipment for the roof in less than a year or so. They just wanna get them thru the rest of this summer cause they are hoping to be into the new building before it gets hot next summer.
  13. #52
    Aug 2012
    MA
    My bad man, TXV or fixed orifice?
