Results 1 to 13 of 18
    Jun 2010
    Charlotte, NC
    What kind of chiller is this?
    This chiller, it looks like it is an aircooled chiller.
    How does it compress the refrigerent? It does not make the typical chiller sound I am used to hearing, much quieter.
    How old is it, and how many tons? Should I be budgeting for replacement and if so, what is a good option?
    It is unusual for me to see a chiller at a small, 8,000 sf building, which unfortunately, is a reheat system, very high utility bills, but I have not figured out any way to convert it to a better system.
    Thanks everyone for being so helpful.
Size:  59.6 KBName:  030.jpg
    Massachusetts
    It's 25 tons, I believe It's manufactured in 1993 if I'm reading the serial number correctly, nice unit, I work on a lot similar but the 15 ton capacity.
    Sent from ivy PC36100 using Tapatalk 2
    Carrier numbers are bigger than capacity so probably a hair under 25 ton. Likely has a Carlyle semihermetic. Those are not known for being quiet!
    Quote Originally Posted by Maikerum View Post
    Not small chiller for that building. It can take care of fresh air.
    As for re-heat strategy was the old school when electricity was dirt cheap. Today, it is illigal to engineer that. As for this building, It will requires better strategies and DDC logics to reduce the elctric bills. The owner would never understand the up-front cost and the saving in the long run.
    Feb 2011
    Chesterfield, Virginia, USA
    It is a little over 20 tons (024 = 20tons) and was made the 45th week of 1993. It should be a standard Carlyle cast iron compressor with one or two unloaders, most likely suction cut-off unloading.
    Fort Worth, TX
    A Carlyle semi-hermetic is more quiet than a 19XR centrifugal with no sound kit!
    Building Physics Rule #2:
    Building Physics Rule #3:
    Jul 2003
    Orange County N.Y.
    Quote Originally Posted by Shophound View Post
    I don't think that you are going to find a 20-25 ton centrifugal chiller. :-) The compressor is enclosed in a cabinet and they are usually quiet enough. Good chillers for the most part as long as you have enough water and a load on them. The one in this post is probably showing its age.
    ...Ron
    Roof Rat
    Fort Worth, TX
    Quote Originally Posted by rscamaro View Post
    ...Ron
    True on the tonnage aspect. But if you put up a rack of Carlyle 06E's (as many higher tonnage recip chillers have) against a screaming 19XR in a loudness contest, I think the high pressure centrifugal would still win. The 06E's purr in comparision to that ear drum shattering squeal.
    OTOH a large tonnage recip chiller (one or two large compressors) can crank out some sound.
    My church has 2 condensing units behind the parish hall. One looks like the chiller pictured except DX, the other is a notch smaller, maybe a 15 ton. When they are on, between the Carlyles and the fans, you can hear them for a block. The big boy for the sanctuary is behind a stone wall 15' high. 1 Carlyle on isn't too bad and fortunately that usually does it. But both on, walking across the courtyard you sure hear them. But then I can remember hearing one centrifugal in the past. Don't recall if Trane or Carrier. Had a loud whine seems to me.
    Jul 2003
    Orange County N.Y.
    That would be correct in some cases. Different impellers creat different sounds. Speed can make a difference in pitch too.
    ...Ron
    Roof Rat
    East of big city prices.
    ...Ron
    Probably a 23XL.
    Jul 2003
    Orange County N.Y.
    Quote Originally Posted by Dallas Duster View Post
    Probably a 23XL.
    That would be a screw machine, which sometimes sound like a box of rocks when running. Only the special ones though.
    ...Ron
    Roof Rat
    ...Ron
    Yep those things are loud.
