Results 27 to 39 of 51
  1. #27
    Jan 2011
    Quote Originally Posted by supertek65 View Post
    what is an MHI chiller?????
    It's a chiller made by Mitsubishi. The MHI stands for Mitsubishi Heavy Industries.
    @flange I would not consider Turbocor compressors in a desert environment. I think they would not spend much time in their sweet spot and quite frankly the numbers I have seen tell me they suck at full load conditions. There are many very large central plants in Dubai many of which are district cooling facilities.
  2. #28
    wow!!!!!!
    they have come a long way since the zeros bombed pearl harbor!!!!!!!!!!!!!
    i hope there arent any af those in any army bases!!!!!!!!! LOL
    Quote Originally Posted by KnewYork View Post
  3. #29
    Jul 2011
    East coast USA
    Quote Originally Posted by flange View Post
    If I were bidding this, I would look at a third solution. With the amount of runtime they get over there verses our traditional cooling season, payback can occur more quickly. we have less degree days for cooling, I would think by a lot. At any rate, if I had the infrastructure in place for RTAA's, I would look at a repalcement using either screws or turbocore, using evap condensing, with all pumps, evaporater, tower etc, all bundled neatly into one package, and set it in place of those rtaa's. you will see similiar kw/ton performance, and less initial cost, but thats just me. payback would be sooner, with less water treatment involved.
    I like your thinking
  4. #30
    A land down under
    Dubai has a design wet bulb of 89 degrees so agree the Turbocor performance would suck, but agree with Flange, given the lack of available wet bulb relief, worth investigating a VSD screw option.
    For information on the Mutsuibishi Centrifugal http://www.mhi.co.jp/en/products/cat...l_chiller.html
  5. #31
    Didnt know it was that high. Yup, I would be all over me some screws, copeland, bristol, whatever they are called these days. I like those pumps.
  6. #32
    I'll take tube-brushing over coil-cleaning any day!
  7. #33
    obviosuly that is preferred for ease of maintenance, however, thinking slightly outside of the proverbial box, there are reasons why my plan might make some sense. first, it offers a quicker payback than a central plant. second, it doesnt generally require any more footprint or a dedicated mechanical room inside a building, which brings on a whole new set of problems such as refirgerant monitoring, ventilaltion, etc.. it is better than an air cooled solution, and can be designed to run very close to or better than total plant kw for a central plant, depending upon the style of centrifigual chosen.
  8. #34
    not to mention here in the states, it is a different type of leverage on the building, potentially creating tax saving opportunity over central plant.
  9. #35
    Jul 2003
    Orange County N.Y.
    Yes, Yes it do suck. Don't recommend it for anyone. The 2nd. to last time I used rods was to get a whole bunch of fill from a tower out of a 1,500 ton absorber bundle. Suck doesn't even start to describe what kind of work that was.
    ...Ron
    Roof Rat
  10. #36
    Saint Joseph, MI
    One more thing I'm not sure I saw mentioned? How greatly do the loads vary? Centrifugals often have minim capacities around 30-50% load. Screws can run down to 10-15% RLA in many cases. I felt that in many cases, centrifugals were best installed in pairs, on a system with a minimum load, or used as base load chillers together with a screw machine.
  11. #37
    Jan 2011
    Quote Originally Posted by motoguy128
    Centrifugals are capable of turning down to 10% load and if equipped with VSD do so quite nicely. Even w/o VSD they can certainly turn down well below 30%. Can't imagine where you are receiving your information.
  12. #38
    Dec 2010
    On a Peninsula in NE NC
    What scrrw will run to10/15 % capacity?, thats not even posible with a screw. I think you have your statement backwards.
  13. #39
    Saint Joseph, MI
    Sorry, I'm probably confusing our air cooled unit with 3 compressors that can run down to 10-12% RLA, but that would still be 30% on one compressor.
    I still remember from training I had on Trane centrifugals and rotary that the rotary would go quite a bit lower. Centrifugals seem more "sensitive" and we walked into one out our chillers rooms and it was getting noisy and RLA was only 60% without any apparent issues. But these are lower temp machines. IN another area, a pair of similar centrfugals were running happily at 48-50%. Who knows, maybe the IGV's need looking at on that one. The approach might have been starting to creep up a little too.
    I guess from my limited experience with Trane units, you can run the screws lower loads than the seemly more sensitive centrifugals that find themselves near the edge of surging at times.
    I thought it was something to factor in. A mutili compressor RTAA will defnitely run a much wider range of loads. SO in this case his 456 ton nominal system with two RTAA's could probably run down to almost 5-8% system capacity. A single centrifugal won't even come close and would need a large storage tank to prevent short cycles whe hte building is under low load, at night, during low occupancy periods.
