Results 14 to 15 of 15
    Jul 2005
    Quote Originally Posted by Pete954 View Post
    The leak was a tiny spot that someone missed while brazing in the sightglass. Nowhere near the evap. Definitely going to suggset cleaning the coil. Hope the boss listens. Thanks all.
    Then let me rephrase. I'd start be leak testing the coil. Literally, that's what I'd do if I were there.
    It doesn't really matter whether someone found a leak near the sight glass, there could be more than one leak in the system. If a leak in the coil is the source of the oil that is causing the condensate drip (if oil is the culprit), then cleaning the coil only to have the dripping start back up in two weeks will look to the customer like you're just guessing at the problem. And they'd be correct, because at this point you are only guessing. If OTOH, you find a leak in the coil first, then you can save yourself the trouble of cleaning it, and from the embarassment of cleaning it only to find that it didn't fix anything. HTH.
    If there is no leak in the coil, then you're only out a few minutes time.
    Jun 2009
    Pompano Bch, S Fla
    Problem solved. Boss wound up cleaning with leak detecting bubbles and said it cleared right up. He was impressed that I came up with the same answer that he got from tech support
    Once again I'd like to thank everyone for their help. Been a member here for a while but starting to get more active.
    You guys are awesome, expect for me to bug you more often
