condensate drain to sump pump pit??
Hi,
My air conditioner condensate pump drains to a covered sump pump pit. The sump pump has never turned on, either from the condensate or from rain. The basement is dry, even when we had that recent hurricane.
My home inspector 3 years ago said the condensate should be pipped outside, not in the sump hole. Is this true? Is it doing any harm?
Thanks.
Steve
 Originally Posted by central nj
Hi,
Thanks.
Steve
You home inspector is a dork.
"Just get it done son."
Dad adjusted
Hi,
Thanks.
Steve
Your sump pump should be exercised regularly, by adding the condensate to the pit will not hurt anything. periodically run water into the pit and let pump run for short period
Its a good place for condensate IMO. Tons of humidity here and very little rain so the condensate kicks the pump on about once a day. The pump needs to run like S.O. said
hvacvegas, second opinion, ar hvac man----A+++++, thanks. Steve.
... is there a condensing gas furnace attached to the drain line too? condensing gas furnaces have an acidic discharge, and it'll damage most sump pumps. aside from that, I see NOTHING wrong with piping a/c condensate to a properly connected sump pump.
I am yourmrfixit
the dilution rate of the water in the crock and the furnace condensate will not have any effect on the pump
too.
Reason: Non AOP member
- You may not post replies
- You may not edit your posts
Forum Rules
