Results 1 to 8 of 8
    Apr 2012
    Princeton NJ
    condensate drain to sump pump pit??
    Hi,
    My air conditioner condensate pump drains to a covered sump pump pit. The sump pump has never turned on, either from the condensate or from rain. The basement is dry, even when we had that recent hurricane.
    My home inspector 3 years ago said the condensate should be pipped outside, not in the sump hole. Is this true? Is it doing any harm?
    Thanks.
    Steve
    Cincinnati, Oh
    Quote Originally Posted by central nj View Post
    Hi,
    Thanks.
    Steve
    You home inspector is a dork.
    "Just get it done son."
    Dad adjusted
    Hi,
    Thanks.
    Steve
    Your sump pump should be exercised regularly, by adding the condensate to the pit will not hurt anything. periodically run water into the pit and let pump run for short period
    NW AR
    Its a good place for condensate IMO. Tons of humidity here and very little rain so the condensate kicks the pump on about once a day. The pump needs to run like S.O. said
    Apr 2012
    Princeton NJ
    hvacvegas, second opinion, ar hvac man----A+++++, thanks. Steve.
    Mar 2009
    Mount Holly, NC
    ... is there a condensing gas furnace attached to the drain line too? condensing gas furnaces have an acidic discharge, and it'll damage most sump pumps. aside from that, I see NOTHING wrong with piping a/c condensate to a properly connected sump pump.
    The three big summer hearththrobs...
    Mel Gibson
    Dwane Johnson
    The A/C repairman
    Quote Originally Posted by vstech View Post
    the dilution rate of the water in the crock and the furnace condensate will not have any effect on the pump
    Jan 2010
    Cedar Rapids, IA
    too.
