Results 1 to 13 of 22
    Need help in deciding between Trane and Rheem...
    I have to make a decision between Rheem and Trane within the next day or so and I'd appreciate any feedback.
    I have a townhouse built in 1988 that still has the original Rheem furnace and A/C (2 ton I think). This is now a rental unit, so due to conversion expense, I'm stuck with an 80% unit. I've had 4 estimates (including NJ PSE&G) and no one has done a load calc... all say I don't need it. Closest thing that was done is 2 contractors took measurements of the downstairs (said they didn't need to go upstairs). I don't have time for more estimates, so I've decided based on who I think is the best contractor (A+ BBB). These numbers included all costs, including permits (Trane is approx $60 more then Rheem)...
    TRANE
    XL80 2-Stage (TUD2B060A9362A)
    XB13 2.5 ton Condenser (4TTB3030E1000A)
    XB series Coil (4FXCB036AC3CAA)
    Rheem
    3 ton 13 Seer Cased Coil (RCFL-HM3617CC)
    2.5 ton Value Series 13 Seer Condensing Unit (13AJA30A01)
    RGPQ 2-Stage (75,000 BTU)
    Note: Furnaces are not variable speed... the extra cost is not justified in a rental unit.
    Tom
    Newark, DE
    The AOP forums/Ask Our Pro's forums, are restricted to only Pro members that have been vetted by the AOPC to post advise, questions or commentary in a thread created by someone else. You need to apply for your vetting/* if you wish to participate in threads in the AOP forums. Please apply to the AOPC today, thank you.
    both are the same 10 years (5 if not registered in 90 days) and life time on the heat exchanger. 1 year labor from the Contractor.
    Nov 2001
    East Texas
    Bump up one notch from the value series condensing unit. Rheem.
    Quote Originally Posted by Timber View Post
    Timber, would you be able to direct me to a specific unit?
    Either would be fine ,as i am more familiar with Trane that would be my choice .i would add a 5 inch media filter being its a rental , that way the indoor unit will stay clean also would get the 10 year part and lobor warranty on yhe system
    Either would be fine ,as i am more familiar with Trane that would be my choice .i would add a 5 inch media filter being its a rental , that way the indoor unit will stay clean also would get the 10 year part and labor warranty on the system
    You're stuttering again.
    Rheem A/C is a "dry" unit meant to be filled with R22. Did you mean 13AJN low end 410 unit?
    Southern California
    Ask for a quote on a Rheem RANL condenser
    Furnace quoted is an 80% 2 stage w/ PSC motor. I have rentals & I wouldn't waste my money on 2 stage anything in a rental. I'd go with the RGPN furnace.
    That would be a good dependable system.
    Make sure filters get changed. Upgrade to better filter wouldn't be a bad idea. I'd at least use a filter base.
    Always drink upstream from the herd
    Nov 2001
    East Texas
    Quote Originally Posted by TomDx View Post
    Any of the classic series
    The 13AJA is what is written in the quote... I have to speak to the Contractor tomorrow... I assume it is just typo.
    Quote Originally Posted by precision hvac View Post
    The reason I'm considering the 2 stage is because the upstairs gets considerably hotter than the downstairs, and I thought it might help. Am I misinformed?
