Results 1 to 13 of 22
08-14-2012, 03:05 PM #1
- Aug 2012
- 21
Need help in deciding between Trane and Rheem...
I have to make a decision between Rheem and Trane within the next day or so and I'd appreciate any feedback.
I have a townhouse built in 1988 that still has the original Rheem furnace and A/C (2 ton I think). This is now a rental unit, so due to conversion expense, I'm stuck with an 80% unit. I've had 4 estimates (including NJ PSE&G) and no one has done a load calc... all say I don't need it. Closest thing that was done is 2 contractors took measurements of the downstairs (said they didn't need to go upstairs). I don't have time for more estimates, so I've decided based on who I think is the best contractor (A+ BBB). These numbers included all costs, including permits (Trane is approx $60 more then Rheem)...
TRANE
XL80 2-Stage (TUD2B060A9362A)
XB13 2.5 ton Condenser (4TTB3030E1000A)
XB series Coil (4FXCB036AC3CAA)
Rheem
3 ton 13 Seer Cased Coil (RCFL-HM3617CC)
2.5 ton Value Series 13 Seer Condensing Unit (13AJA30A01)
RGPQ 2-Stage (75,000 BTU)
Note: Furnaces are not variable speed... the extra cost is not justified in a rental unit.
Tom
08-14-2012, 03:41 PM #2
- Jan 2008
- Newark, DE
- 10
The AOP forums/Ask Our Pro's forums, are restricted to only Pro members that have been vetted by the AOPC to post advise, questions or commentary in a thread created by someone else. You need to apply for your vetting/* if you wish to participate in threads in the AOP forums. Please apply to the AOPC today, thank you.
You can find the rules for posting and qualifications here.Last edited by beenthere; 08-14-2012 at 08:36 PM. Reason: Non Pro * Member
08-14-2012, 03:44 PM #3
- Aug 2012
- 21
both are the same 10 years (5 if not registered in 90 days) and life time on the heat exchanger. 1 year labor from the Contractor.
08-14-2012, 04:01 PM #4
Professional Member*
- Nov 2001
- East Texas
- 832
Bump up one notch from the value series condensing unit. Rheem.
08-14-2012, 04:08 PM #5
- Aug 2012
- 21
08-14-2012, 04:51 PM #6
- Jul 2006
- Virginia
- 3,706
Either would be fine ,as i am more familiar with Trane that would be my choice .i would add a 5 inch media filter being its a rental , that way the indoor unit will stay clean also would get the 10 year part and lobor warranty on yhe system
08-14-2012, 04:57 PM #7
- Jul 2006
- Virginia
- 3,706
Either would be fine ,as i am more familiar with Trane that would be my choice .i would add a 5 inch media filter being its a rental , that way the indoor unit will stay clean also would get the 10 year part and labor warranty on the system
08-14-2012, 05:12 PM #8
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
08-14-2012, 09:26 PM #9
Rheem A/C is a "dry" unit meant to be filled with R22. Did you mean 13AJN low end 410 unit?
08-14-2012, 10:05 PM #10
Ask for a quote on a Rheem RANL condenser
Furnace quoted is an 80% 2 stage w/ PSC motor. I have rentals & I wouldn't waste my money on 2 stage anything in a rental. I'd go with the RGPN furnace.
That would be a good dependable system.
Make sure filters get changed. Upgrade to better filter wouldn't be a bad idea. I'd at least use a filter base.Always drink upstream from the herd
08-14-2012, 10:13 PM #11
- Nov 2001
- East Texas
- 832
08-14-2012, 10:37 PM #12
- Aug 2012
- 21
08-14-2012, 10:43 PM #13
- Aug 2012
- 21
