Results 1 to 6 of 6
    chiller 240 more info
    Compressor will run for about 20 to 30 seconds and kicks off same code as. Yesterday is their a way to run the unloader so compressor starts as it should ?
    MEXICO
    that model of machine is? gives more information
    Quote Originally Posted by ed-man View Post
    you need to keep new information on the other thread that you started.
    The weak aren't destroyed by the strong.
    The weak are destroyed by the under-estimated.
    I know a famous song that ends in 'my nose'. The artist is dead. Know who?
    Mar 2011
    North Carolina Piedmont Area
    Are you still playing with that chiller........What do you mean start as it should. It should start unloaded and go through transition if its a closed transition starter.
    Trouble shooting is not part of the repair
    ___________________________________________
    Understand the symptoms and you will find a solution
    The Hot South
    I'm not even going to waste my time on this one.
    Mar 2011
    Quote Originally Posted by R123 View Post
    I wonder what it means when the screw sound like their grinding.......LOL
