Results 1 to 13 of 17
    Oct 2010
    AZ
    Are Filter/driers required on new installs
    My brother just had a house built and I noticed there is no filter/drier on his ac. It is a brand new install. I brought this up to the general contractor and he told me it is not required on new installs. Assuming (and I know this is a big assumption) the lines were nitrogen purged while brazing and evacuated below 50 microns, this shouldn't be a big deal. However, I seem to recall manufacturers requiring their installation on new units. Couldn't find any requirement in the IMC. Anyone know if there is a code requirement or manufacturer requirement for a Filter/drier.
    Mar 2011
    This is what the Ruud installation manual said. They actually provide a filter dryer with the unit- UPQL condensor.
    As an added precaution, a high quality, bi-directional filter drier is recommend- ed to be installed in the liquid line, if not factory installed.
    Quote Originally Posted by dijit View Post
    What brand of equipment?
    Jun 2009
    Upstate SC
    Look inside the unit to make sure its not there.
    Sent from my ERIS using Tapatalk 2
    Oct 2010
    AZ
    Goodman
    Oct 2010
    AZ
    I will check.
    I will check.
    Factory installed
    Oct 2010
    AZ
    Factory installed
    In condenser unit?
    In condenser unit?
    Yes
    His installers pull a vacuum below 50 microns??? Sure! Most RNC installers wouldn't know what a micron gauge is, some around us may not even use a vacuum pump judging from our findings
    Oct 2010
    AZ
    I know, I have seen that too. That's what concerns me. Even saw a guy that had like 5 years of "experience" in commercial that didn't know how to use a vacuum pump. Of course his daddy also worked at the same company.
    Nov 2007
    Mississippi
    I think all Goodman condensers come with a factory installed drier. I hate this because I don't have the option to pump down to replace. I like to move them outside the condenser after the first recovery.
    Quote Originally Posted by socotech View Post
    Why not?
