Page 3 of 6 FirstFirst 123456 LastLast
Results 27 to 39 of 66
  1. #27
    florida
    Quote Originally Posted by Lennyb View Post
    I did try and turn off the TXV's cap, but I didn't have room to get any wrenches on it. It has been replaced sometime before and adjusting TXV obviously wasn't on the installers adgenda. It is an externally equalized TXV with a removeable power head. I wanted to open up TXV some but like I said impossible to get a wrench on it. I will try later when Im back to the Unit with a socket.
    It's attached with copper and the last time I did one the copper bends real easy.
    Educational forums are open.
  2. #28
    Lancaster PA
    Depends how cold the freezer is, and what temp it is outside. Mild temp day, 230 head, -10 in the box, 16.
  3. #29
    Feb 2012
    16 PSIG on suction line in good all around conditions? Which would be about -22 on Gauge? So for a SH of 18-20 that means Im looking for a suction line temp of about zero??? Doesn't sound right!!! That would surely freeze up suction line and compressor etc.
    SH=Suction line Temp - Evap temp
    Or I thought
  4. #30
    Lancaster PA
    You don't work on freezers often, do you?
  5. #31
    florida
    Or I thought
    Oh Boy.
  6. #32
  7. #33
    Mar 2009
    Mid-Mo
    If only I could paid extra for those "froze up" calls where the accumulator has ice on it....I could probably afford that nice Caribbean vacation the wife has been wanting for 2 years!
    Don't sweat the ice....you're in the home stretch now. sounds like you have the problem narrowed down, seal the deal.
  8. #34
    Apr 2001
    MINN
    Is there a stainer on that TEV?
  9. #35
    Jul 2012
    Western KY
    Or I thought
    SH 18-20? Ok don't be offended but you are not looking for the right numbers the right way. SH is the difference between saturated suction temp and actual suction temp and it should be 6-10 at the TXV bulb on a WI freezer. Agin don't be offended I'm not picking just wanna get you goin in the right direction.
  10. #36
    Jul 2012
    Western KY
    Also don't worry about frosting of the suction line it's going to happen if not insulated because the line temp will be well below 0 on a -10 degree box. The comp will not freeze up if charge and SH are correct.
  11. #37
    Feb 2012
    No mostly heat pumps and coolers
  12. #38
    Feb 2012
    So your saying that the Evap line temp at the TXV bulb should be 6-10 for a 404a freezer? Also maybe im just slow but I was under the impression I understood SH
  13. #39
    Feb 2012
    With R22, 410A, and coolers with 414B, 409A, and 404a. Only 3 freezers on property.
