Page 2 of 6 FirstFirst 123456 LastLast
Results 14 to 26 of 66
    Quote Originally Posted by Dad View Post
    Rough day at the spelling bee Jim?
    The last hot attic I was in today, killed me.
    Feb 2012
    Quote Originally Posted by ar_hvac_man View Post
    Make sure the coil is completely clear of ice. Many times once you get the back clear you will still have ice on the front. Measure your SH at the evaporator.
    Does the unit have an accumulator? There will be a very large diff in SH if you measure the line going into the accumulator and the line coming out and going into the compressor.
    Yes It has an accumulator
    Feb 2012
    When I add refrigerant low side pressures drop and it raises my superheat. Sight glass has no bubbles
    Quote Originally Posted by Lennyb View Post
    You don't adjust superheat on a refrigeration system by adding or removing charge.
    You adjust the superheat by adjusting (or repairing the TEV).
    Now that we have a clear sightglass, let's dismiss the idea of low charge for now.
    Since the TEV regulates the amount of refrigerant that goes into the evaporator, thus controlling superheat, we might want to take a look at that before we add any more gas.
    Feb 2012
    Condensor ambient temp was approx 90 deg F
    Feb 2012
    I did try and turn off the TXV's cap, but I didn't have room to get any wrenches on it. It has been replaced sometime before and adjusting TXV obviously wasn't on the installers adgenda. It is an externally equalized TXV with a removeable power head. I wanted to open up TXV some but like I said impossible to get a wrench on it. I will try later when Im back to the Unit with a socket.
    There's always a way.
    It isn't always easy, but there IS a way.
    Oh, by "cap" you do mean the adjustment cap and not the power element, right? You take that off without pumping the system down first and
    R404A at 175 PSIG is a sat of 80°F.
    Where did you take the LL pressure? Might have a restricted LLFD.
    Let's go about this a different and much better way, shall we?
    OP...
    Model of condenser/compressor and age of this unit
    Amp draws of the compressor while under a load
    Model of evap and age of this unit
    TXV information and cartridge size along with location of bulb and how it is mounted
    Orifice size in distributor if there is one
    Head pressure
    Suction pressure
    Suction line temp at the evap coil outlet
    Any pertinent work preformed on this box and what was it doing before that required such work.
    Stop guessing guys. Let's get the facts first, yes?
    florida
    OP...
    Head pressure
    Suction pressure
    X2 we need info first.
    Educational forums are open.
    Feb 2012
    No not the power head lol, yes the adjustment cap so I can get a refrigerant wrench on it.
    Feb 2012
    175 PSIG was off the liquid line receiver. What would good low and high side PSIG be for a 404a freezer application ?
