Page 1 of 6 123456 LastLast
Results 1 to 13 of 66
    Feb 2012
    404A Freezer Issue
    I have a 404A split system walkin with line setts approx 30 ft, I have a box temp of 12 deg F and dropping. System Pressures are 25 PSIG Low side and 175 PSIG High side. 12 inches from Compressor I get a 45 deg F. When adding 404A the low side pressures temp and PSIG drop raising my superheat. Currently my superheat is approx 55 deg F. After de-Iceing evap coil and TXV and Selnoid valve I noticed TXV is frosting up imediately. I changed the selnoid coil and no change.
    My thoughts are recovery refridgerant and change both TXV and selniod valve. Approximately 6 months ago the coil went bad on the valve... Any suggestions or thoughts???
    Dec 2009
    You have a low refrigerant charge.
    Lancaster PA
    Quote Originally Posted by KickedGinger View Post
    looks that way.
    Your SOLENOID shouldn't be icing up. I am reading this right that you de-iced it right?
    Sent from my SCH-I800 using Tapatalk
    Aug 2012
    Georgia
    Do you happen to have a sight glass installed? I'm surprised your box temp is 12 with that superheat.
    California
    low on gas, restricted drier, restricted TEV.
    Do you have a liquid sight glass?
    Need to dig deeper.
    55* superheat and a 12* box is fishy
    Aug 2012
    Palmyra MO
    Is the coil still froze up. Make sure both sides of the coil are free of ice.
    Feb 2012
    Quote Originally Posted by drife678 View Post
    Sight glass yes, no bubbles....
    Selnoid was frozen up because the whole side with TXV, seloid, and fan delay all were under a solid block of ice.
    Feb 2012
    Both sides of evap coil were cleared.
    NW AR
    Make sure the coil is completely clear of ice. Many times once you get the back clear you will still have ice on the front. Measure your SH at the evaporator.
    Does the unit have an accumulator? There will be a very large diff in SH if you measure the line going into the accumulator and the line coming out and going into the compressor.
    Lancaster PA
    Whats the ambient temp at the condenser.
