Page 6 of 8 FirstFirst 12345678 LastLast
Results 66 to 78 of 103
Thread: vacum setup
  1. #66
    Jan 2013
    Quote Originally Posted by 270wsm View Post
    How much faster would vacuum go if I changed my 3/8 vacuum port on my pump to 1/2" and used a 1/2 tee instead if 3/8 and ordered my Appion 1/2" hoses with 1/2 connection instead of the standard 3/8" connection???
    The only realistic answer is the the evacuation time wold decrease "noticeably". The variables are just too numerous to give a pat answer.
  2. #67
    Oct 2009
    Raleigh, NC
    Quote Originally Posted by hvaclover View Post
    I'd thought of thought too, but when I bought one from HD, the pipe threads just didn't seem right..Chink made of course.
    Just didn't want to take a chance on cross threading the pumpm intake.
    Some take NPT and others take MPT. So you have to be care ful on what you buy.
    I got my one of my tees from Fastenal and it cost 2.99.
    I talked to a local vac pump servicer and got my sizes straight before I took the plunge. You cross thread the the in take you are in for some expensive OEM parts
    Ignoring the obvious racially insensitive remark, aren't National Pipe Thread and Male Pipe Thread the same thing?
  3. #68
    Jan 2013
    Quote Originally Posted by MicahWes View Post
    No.
    One is tapered and one is straight.
    FYI...that's just the way Uncle Clover expresses Himself.
  4. #69
    Oct 2009
    Raleigh, NC
    I have always known them to be the exact same thing. I only spent five minutes looking just now, but I don't see anything on the internet that says any different.
    Sent from my ADR6350 using Tapatalk 2
  5. #70
    In a machine room
    vacum setup
    They are exactly the same, both have tapered threads. http://engineeringtoolbox.com/npt-national-pipe-taper-threads-d_750.html
  6. #71
    May 2012
    Nova Scotia, Canada
    How often so you guys clean your micron gauges?
  7. #72
    Jan 2013
    You are correct. I was mistaken.
  8. #73
    Feb 2013
    NE philly
    i wanna buy one whats the company who makes it?
  9. #74
    Oct 2008
    Ohio, USA
    Something to remember:
    I have the appion flow rig with 1/2 hoses, an appion vacuum pump, and a bluvac.
    I was recently working on a small system (double door reach in cooler) after a compressor change-out, and was only able to get to 1000 microns.
    I was trying everything. Tightening all hose connections gorilla tight. Nitrogen purging. Leaking king valve stem? Leak somewhere else?
    Then I took all my hoses and connectors apart, and dabbed some Nylog on the ends. (it's been a few months since I did this)
    Hooked back up, went down to ~300 microns in 20 secs.
    Lesson learned.
  10. #75
    Jun 2002
    south jersey
    I have used the Nylog. I am afraid it is going to clog the port. In the video on the website they use it on shraders. It is pretty thick stuff. Especially the one for r-22. Has anybody ever had a problem. When I use it on the face of flares it looks like it will clog the pipe. This makes me afraid to use it on shrader ports.
  11. #76
    Feb 2012
    Toronto Canada
    I am testing out nylog Tommorow for the first time. I didn't like how I had to buy to different kinds.
    So what is the part# for the tee that everyone uses for their vacuum setup?
  12. #77
    Calgary, Alberta
    Quote Originally Posted by OldSchoolMech View Post
    I'm pretty confident the HFC nylon is compatible to cfc and hcfc.
    It works wonders for evacuation.
  13. #78
    Jul 2009
    Columbia, MD
    OldSchoolMech. Just use the blue nylog HFC. it will work on both 22 and 410. it is also easier to work with. the red stuff is super tacky
