Results 1 to 9 of 9
    Feb 2011
    Orange County, in a Galaxy far far away...
    WTF Fieldpiece breaking down on me...
    Well I don't know if its the heat or something else but on Thursday my 3 month old HS36 wouldn't read amps correctly. Its auto ranging and reads numbers with a decimal point, the M and K symbol flash on and off while it hunts through the range. Never used to do that, before it was turn to VAC, hook on clamp and read amps. Tried resetting, changing batteries. Pretty much every tip I could find on line, no joy. But hey I'll use an amp clamp from my friends hs33 !
    Well **** me sideways the readings were still goofy, I thought okay, button up and call fieldpiece. No answer, hhmmmm. anyway right as I was pulling the leads out the common pin inside the head attachment came off!!!
    Great, just great.
    Now to cap things off I tested it again on my own a/c unit at home Thursday night, put the magnetic strap on the back onto the condenser (as I have done a thousand times with hs33 and this meter) and promptly watched my meter fall to the ground!!
    Aaarrggghhhh!!!!!!!!!
    Friday morning bought another HS36 from J-mart, a tech without a meter is like a Dr. without a stethoscope.
    BTW i bought another HS36 because I have a bunch of head attachments, fan, gas pressure, Co detector, flame diode, amp clamp, K-type thermoclamp etc. Switching to Fluke just isn't practical at this point.
    Sigh...
    You cannot cheat an honest man. But that doesn't stop people trying!
    May 2010
    Canada
    3 months old. Call fieldpiece I'm positive they will help you out.
    Jul 2009
    Kansas
    Yes they do have a 1 year warranty so Fieldpiece should be able to help you if anything you'll at least get another new meter.
    Feb 2011
    Already got a response from Russell at Fieldpiece. He's out of town but Jeremy is on the case now. Will update everyone on here with my experience (probably good and what we find.
    May 2010
    Canada
    If you end up with two hs36 I'll trade you a sc77 (refurbished and never used) for the repaired Hs36.
    Feb 2011
    Many thanks to Russell and Jeremy at Fieldpiece.
    Dropped by the HQ today between service calls and everything was handled in under 10 minutes. That blew me away. Time is precious to me right now especially with service calls stacking up!
    I now have 2 fully working hs36's one still in the wrapper.
    Nov 2001
    East Texas
    Dang, wish they would send me the looong test leads. I got shorted on the ones that come with the sc56..................
    louisville, ky
    yea, the fieldpiece leads are shorter than fluke leads, i use fluke leads with me fieldpiece meters for the longer reach, and i like the fact that they are one piece, the fieldpiece leads come apart so u can hook aligater clips to them, i dont like leads like that, the connection could get weak and not sense voltage and that would suck.
    Quote Originally Posted by Vettgetsmwet04 View Post
    I got the longer Fluke leads that come apart cause I wanted some of the nice spring jaw attachments. FWIW If you look close at the Fluke connection there are many more points of contact vs the Fieldpiece ones. I wouldn't doubt it if the Flukes where made from better material too.... at least it seems that way to me. I could have bought a whole Fieldpiece meter for what they cost though
