Results 14 to 25 of 25
Thread: Testo gauges.
    Aug 2010
    Coral Springs, Florida
    That is confusing how they wrote it.
    So is "±1 Digit" ±1 micron? Thats better than a BluVac
    Looks like ±1 digit translates to one tic on their scale which is ±500 microns
    Hi, Ice.
    Looking at the Testo 557 datasheet, it rates vacuum accuracy as +/- 1% FS (Full Scale) +/- 1 digit (at 22C).
    This is a helluva way to rate a micron gauge! I don't know what they consider as "full scale", but, generally, when working with vacuum, I would consider FS to be 760,000 microns. Therefore, 1% FS would be 7,600 microns! In addition, 1 digit, represents 500 microns, as you have indicated.
    From my vantage point, then, a reading of +/- 8,100 microns (at any vacuum level and at 22C) would be within factory spec. And no specs are given outside of the 22C temperature point. TIFWIW!
    Full disclosure for those who don't know: I am the inventer, designer, and manufacturer of the AccuTools BluVac & BluVac LTE gauges.
    Edit: Upon further reading of the datasheet, the vacuum range is 0 to 1 bar. So, one bar, or 750,064 microns, should be "full scale".
    May 2010
    Canada
    what is the accuracy of the bluvac?
    Aug 2012
    I'm getting a Testo anyway. Just deciding on which vacuum gauge.
    The fieldpiece look good value at $126.
    Quote Originally Posted by Itstony View Post
    IMO Stick with the vacuum indicator in the testo gauge till you can afford anything but the very best micron gauge like a Thermal or BluVac. Anything else will be a headache
    Aug 2012
    OK, I will go for the BluVac lite. Just waiting for Jim from Trutech to get back to me.
    Aug 2010
    Quote Originally Posted by eddiegoodfellar View Post
    The BluVacs' rated accuracy is +/- 5% (of reading) +/- 5 microns from 10°F to 122°F (-12°C to 50°C).
    Additionally, the BluVacs can be recalibrated to factory specifications simply by placing it in your freezer. No return to factory necessary for calibration.
    May 2010
    Canada
    So if we are sitting at 1000 microns on the Bluvac
    It would be in the 1045 micron to 945 micron range?
    Aug 2012
    It would be good eddie if anybody that uses the 557/570 along with a stand alone vac-gauge could contribute.
    Your statement may be tongue in cheek, but that is exactlty what Testo's spec sheet says.
    For HVAC it makes me wonder if this feature is "Showing us what we could have won".
    May 2010
    Canada
    No tongue in cheek intended. I have been tricked in the past with accuracy,scale,resolution and count on meters before.
    **I should have wrote 1055microns not 1045microns
    Aug 2010
    As you indicated in your correction above, 945 to 1055.
    May 2010
    Canada
    Thank you.
    Aug 2010
